RTEMS 6.1-rc1
Files | Data Structures | Typedefs | Functions | Variables
Thread-Local Storage (TLS)
This group contains the implementation to support thread-local storage (TLS). More...
file  tls.h
 This header file provides the interfaces of the Thread-Local Storage (TLS).
file  tlsallocsize.c
 This source file contains the implementation of _TLS_Get_allocation_size().
struct  TLS_Configuration
 Represents the TLS configuration. More...
struct  TLS_Dynamic_thread_vector
struct  TLS_Thread_control_block
struct  TLS_Index
typedef struct TLS_Thread_control_block TLS_Thread_control_block
uintptr_t _TLS_Get_allocation_size (void)
 Gets the allocation size of the thread-local storage area in bytes. More...
const volatile TLS_Configuration _TLS_Configuration
 Provides the TLS configuration. More...
Variants I and II are according to Ulrich Drepper, "ELF Handling For Thread-Local Storage".
◆ _TLS_Get_allocation_size()
uintptr_t _TLS_Get_allocation_size ( void  )
Returns
Returns the allocation size of the thread-local storage area in bytes.
Variable Documentation
◆ _TLS_Configuration
extern
Directly using symbols with an arbitrary absolute address such as _TLS_Alignment may not work with all code models (for example the AArch64 tiny and small code models). Store the addresses in a read-only object. Using the volatile qualifier ensures that the compiler actually loads the address from the object.
