RTEMS 6.1-rc1
Files | Data Structures | Macros | Enumerations
Multiprocessing (MP) Packet Handler
This group contains the Multiprocessing (MP) Packet Handler implementation. More...
file  mppkt.h
 This header file provides the interfaces of the Multiprocessing (MP) Packet Handler.
struct  MP_packet_Prefix
#define MP_PACKET_CLASSES_FIRST   MP_PACKET_MPCI_INTERNAL
#define MP_PACKET_CLASSES_LAST   MP_PACKET_SIGNAL
#define MP_PACKET_MINIMUM_PACKET_SIZE   64
#define MP_PACKET_MINIMUN_HETERO_CONVERSION    ( sizeof( MP_packet_Prefix ) / sizeof( uint32_t ) )
enum  MP_packet_Classes {
  MP_PACKET_MPCI_INTERNAL = 0 , MP_PACKET_TASKS = 1 , MP_PACKET_MESSAGE_QUEUE = 2 , MP_PACKET_SEMAPHORE = 3 ,
  MP_PACKET_PARTITION = 4 , MP_PACKET_REGION = 5 , MP_PACKET_EVENT = 6 , MP_PACKET_SIGNAL = 7
This handler encapsulates the primary definition of MPCI packets. This handler defines the part of the packet that is common to all remote operations. It defines the basic packet and provides mechanisms to utilize packets based on this prefix. Packets are the fundamental basis for messages passed between nodes in an MP system.
◆ MP_PACKET_CLASSES_FIRST
This constant defines the first entry in the MP_packet_Classes enumeration.
◆ MP_PACKET_CLASSES_LAST
This constant defines the last entry in the MP_packet_Classes enumeration.
◆ MP_PACKET_MINIMUM_PACKET_SIZE
An MPCI must support packets of at least this size.
◆ MP_PACKET_MINIMUN_HETERO_CONVERSION
The following constant defines the number of uint32_t's in a packet which must be converted to native format in a heterogeneous system. In packets longer than MP_PACKET_MINIMUN_HETERO_CONVERSION uint32_t's, some of the "extra" data may a user message buffer which is not automatically endian swapped.
◆ MP_packet_Classes
The following enumerated type defines the packet classes.
Note
In general, each class corresponds to a manager which supports global operations. Each manager defines the set of supported operations.
