RTEMS 6.1-rc1
This group contains the Clock Manager implementation. More...
Files | |
file | clock.h |
This header file defines the Clock Manager API. | |
file | clockimpl.h |
This header file provides the implementation interfaces of the Clock Manager. | |
file | clockgetsecondssinceepoch.c |
This source file contains the implementation of rtems_clock_get_seconds_since_epoch(). | |
file | clockgettickspersecond.c |
This source file contains the implementation of rtems_clock_get_ticks_per_second(). | |
file | clockgettickssinceboot.c |
This source file contains the implementation of rtems_clock_get_ticks_since_boot(). | |
file | clockgettod.c |
This source file contains the implementation of rtems_clock_get_tod(). | |
file | clockgettodtimeval.c |
This source file contains the implementation of rtems_clock_get_tod_timeval(). | |
file | clockgetuptime.c |
This source file contains the implementation of rtems_clock_get_uptime(). | |
file | clockgetuptimenanoseconds.c |
This source file contains the implementation of rtems_clock_get_uptime_nanoseconds(). | |
file | clockgetuptimeseconds.c |
This source file contains the implementation of rtems_clock_get_uptime_seconds(). | |
file | clockgetuptimetimeval.c |
This source file contains the implementation of rtems_clock_get_uptime_timeval(). | |
file | clockset.c |
This source file contains the implementation of rtems_clock_set(). | |
file | clocktick.c |
This source file contains the implementation of rtems_clock_tick(). | |
file | clocktodtoseconds.c |
This source file contains the implementation of _TOD_To_seconds(). | |
file | clocktodvalidate.c |
This source file contains the implementation of _TOD_Validate(). | |
Enumerations | |
enum | TOD_Ticks_validation { TOD_DISABLE_TICKS_VALIDATION = 0 , TOD_ENABLE_TICKS_VALIDATION = -1 } |
The enumerators of this type determine if the ticks member is validated in _TOD_Validate(). More... | |
rtems_status_code | _TOD_Validate (const rtems_time_of_day *the_tod, TOD_Ticks_validation ticks_validation) |
Validates the time of day. More... | |
Watchdog_Interval | _TOD_To_seconds (const rtems_time_of_day *the_tod) |
TOD to Seconds. More... | |
enum TOD_Ticks_validation |
Enumerator | |
TOD_DISABLE_TICKS_VALIDATION | Use this option to disable the validation of the ticks member in _TOD_Validate(). |
TOD_ENABLE_TICKS_VALIDATION | Use this option to enable the validation of the ticks member in _TOD_Validate(). |
Watchdog_Interval _TOD_To_seconds | ( | const rtems_time_of_day * | the_tod | ) |
TOD to Seconds.
This function returns the number seconds between the epoch and the_tod.
[in] | the_tod | is the TOD structure to convert to seconds |
This | method returns the number of seconds since epoch represented by the_tod |
rtems_status_code _TOD_Validate | ( | const rtems_time_of_day * | the_tod, |
TOD_Ticks_validation | ticks_validation | ||
the_tod | is the reference to the time of day structure to validate or NULL. |
ticks_validation | indicates if the ticks member of the time of day should be validated. Use TOD_ENABLE_TICKS_VALIDATION to validate the ticks member. Use TOD_DISABLE_TICKS_VALIDATION to skip the validation of the ticks member. |
RTEMS_SUCCESSFUL | the_tod references a valid time of day. |
RTEMS_INVALID_CLOCK | the_tod references an invalid time of day. |
RTEMS_INVALID_ADDRESS | the_tod reference is NULL . |
