RTEMS 6.1-rc1
This group contains the SPWTDP interfaces. More...
Modules | |
Command Elapsed Time 0 (CET0) | |
This group contains register bit definitions. | |
Command Elapsed Time 1 (CET1) | |
Command Elapsed Time 2 (CET2) | |
Command Elapsed Time 3 (CET3) | |
Command Elapsed Time 4 (CET4) | |
Configuration 0 (CONF0) | |
Configuration 3 (CONF3) | |
Control (CTRL) | |
Datation Elapsed Time 0 (DET0) | |
Datation Elapsed Time 1 (DET1) | |
Datation Elapsed Time 2 (DET2) | |
Datation Elapsed Time 3 (DET3) | |
Datation Elapsed Time 4 (DET4) | |
Datation Preamble Field (DPF) | |
Delay Count (DC) | |
Disable Sync (DS) | |
External Datation 0 Elapsed Time 0 (ED0ET0) | |
External Datation 0 Elapsed Time 1 (ED0ET1) | |
External Datation 0 Elapsed Time 2 (ED0ET2) | |
External Datation 0 Elapsed Time 3 (ED0ET3) | |
External Datation 0 Elapsed Time 4 (ED0ET4) | |
External Datation 0 Mask (EDM0) | |
External Datation 0 Preamble Field (EDPF0) | |
Interrupt Enable (IE) | |
Latency Preamble Field (LPF) | |
Time Stamp Elapsed Time 0 Rx (TR0) | |
Time Stamp Elapsed Time 0 Tx (TT0) | |
Time Stamp Elapsed Time 1 Rx (TR1) | |
Time Stamp Elapsed Time 1 Tx (TT1) | |
Time Stamp Elapsed Time 2 Rx (TR2) | |
Time Stamp Elapsed Time 2 Tx (TT2) | |
Time Stamp Elapsed Time 3 Rx (TR3) | |
Time Stamp Elapsed Time 3 Tx (TT3) | |
Time Stamp Elapsed Time 4 Rx (TR4) | |
Time Stamp Elapsed Time 4 Tx (TT4) | |
Time-Stamp Preamble Field Rx (TRPFRX) | |
Time-Stamp SpaceWire Time-Code and Preamble Field Tx (TTPFTX) | |
Files | |
file | spwtdp-regs.h |
This header file defines the SPWTDP register block interface. | |
struct | spwtdp |
This structure defines the SPWTDP register block memory map. More... | |
Typedefs | |
typedef struct spwtdp | spwtdp |
This structure defines the SPWTDP register block memory map. | |
