RTEMS 6.1-rc1
Modules | Files | Data Structures | Typedefs
This group contains the GRGPIO interfaces. More...
 Bypass register (BYPASS)
 This group contains register bit definitions.
 Capability register (CAP)
 I/O port data register (DATA)
 I/O port direction register (DIRECTION)
 I/O port output register (OUTPUT)
 Interrupt available register (IAVAIL)
 Interrupt edge register (IEDGE)
 Interrupt enable register (IPEN)
 Interrupt flag register (IFLAG)
 Interrupt map register n, where n = 0 .. 3 (IRQMAPR)
 Interrupt mask register (IMASK)
 Interrupt polarity register (IPOL)
 Logical-AND registers (LAND)
 Logical-OR registers (LOR)
 Logical-XOR registers (LXOR)
 Pulse register (PULSE)
file  grgpio-regs.h
 This header file defines the GRGPIO register block interface.
struct  grgpio
 This structure defines the GRGPIO register block memory map. More...
typedef struct grgpio grgpio
