AMBA Plag & Play Bus Driver Macros.
More...
#define | GRLIB_IO_AREA 0xfff00000 |
#define | GRLIB_CONF_AREA 0xff000 |
#define | GRLIB_AHB_SLAVE_CONF_AREA (1 << 11) |
#define | GRLIB_AHB_CONF_WORDS 8 |
#define | GRLIB_APB_CONF_WORDS 2 |
#define | GRLIB_AHB_MASTERS 64 |
#define | GRLIB_AHB_SLAVES 64 |
#define | GRLIB_APB_SLAVES 16 |
#define | GRLIB_CLOCK_INDEX 0 |
#define | GRLIB_COUNTER_GPTIMER_INDEX GRLIB_CLOCK_INDEX |
#define | GRLIB_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER 1000000 |
#define | GRLIB_IRQMPSTATUS_CPUNR 28 |
#define | GRLIB_IRQCTRL_ACQUIRE(_lock_context) rtems_interrupt_lock_acquire( &GRLIB_IrqCtrl_Lock, _lock_context ) |
#define | GRLIB_IRQCTRL_RELEASE(_lock_context) rtems_interrupt_lock_release( &GRLIB_IrqCtrl_Lock, _lock_context ) |
#define | GRLIB_Cpu_Unmask_interrupt(_source, _cpu) |
#define | GRLIB_Cpu_Mask_interrupt(_source, _cpu) |
#define | GRLIB_Enable_interrupt_broadcast(_source) |
#define | GRLIB_Disable_interrupt_broadcast(_source) |
#define | BSP_Cpu_Is_interrupt_masked(_source, _cpu) (!(GRLIB_IrqCtrl_Regs->mask[_cpu] & (1U << (_source)))) |
void | gptimer_initialize (void) |
void | irqmp_initialize (void) |
◆ GRLIB_Cpu_Mask_interrupt
#define GRLIB_Cpu_Mask_interrupt |
_source, |
_cpu |
Value: do { \
rtems_interrupt_lock_context _lock_context; \
GRLIB_IRQCTRL_ACQUIRE( &_lock_context ); \
GRLIB_IrqCtrl_Regs->mask[_cpu] &= ~(1U << (_source)); \
GRLIB_IRQCTRL_RELEASE( &_lock_context ); \
} while (0)
◆ GRLIB_Cpu_Unmask_interrupt
#define GRLIB_Cpu_Unmask_interrupt |
_source, |
_cpu |
Value: do { \
GRLIB_IrqCtrl_Regs->mask[_cpu] |= (1U << (_source)); \
} while (0)
◆ GRLIB_Disable_interrupt_broadcast
#define GRLIB_Disable_interrupt_broadcast |
_source | ) |
Value: do { \
uint32_t _mask = 1U << ( _source ); \
GRLIB_IrqCtrl_Regs->bcast &= ~_mask; \
} while (0)
◆ GRLIB_Enable_interrupt_broadcast
#define GRLIB_Enable_interrupt_broadcast |
_source | ) |
Value: do { \
GRLIB_IrqCtrl_Regs->bcast |= _mask; \
} while (0)
