RTEMS 6.1-rc1
Files | Macros | Functions | Variables
TQM8XX Board Support Package. More...
file  bsp.h
 Global BSP definitions.
#define BSP_HAS_TQMMON
#define NOCACHE_MEM_SIZE   512*1024
#define PGHPLUS_SPI_ADDR_EEPROM   0
#define PGHPLUS_SPI_ADDR_DISP4   1
#define PGHPLUS_SPI_ADDR_DISP4_DATA   (PGHPLUS_SPI_ADDR_DISP4)
#define PGHPLUS_SPI_ADDR_DISP4_CTRL   (PGHPLUS_SPI_ADDR_DISP4_DATA+1)
#define PGHPLUS_PB_SPI_EEP_CE_MSK   (1<< 0)
#define PGHPLUS_PB_SPI_DISP4_RS_MSK   (1<<15)
#define PGHPLUS_PB_SPI_DISP4_CE_MSK   (1<<14)
 LINKER_SYMBOL (TopRamReserved)
 LINKER_SYMBOL (bsp_ram_start)
 LINKER_SYMBOL (bsp_ram_end)
 LINKER_SYMBOL (bsp_ram_size)
 LINKER_SYMBOL (bsp_rom_start)
 LINKER_SYMBOL (bsp_rom_end)
 LINKER_SYMBOL (bsp_rom_size)
 LINKER_SYMBOL (bsp_section_text_start)
 LINKER_SYMBOL (bsp_section_text_end)
 LINKER_SYMBOL (bsp_section_text_size)
 LINKER_SYMBOL (bsp_section_data_start)
 LINKER_SYMBOL (bsp_section_data_end)
 LINKER_SYMBOL (bsp_section_data_size)
 LINKER_SYMBOL (bsp_section_bss_start)
 LINKER_SYMBOL (bsp_section_bss_end)
 LINKER_SYMBOL (bsp_section_bss_size)
 LINKER_SYMBOL (bsp_work_area_start)
int BSP_disconnect_clock_handler (void)
int BSP_connect_clock_handler (rtems_irq_hdl)
char serial_getc (void)
int serial_tstc (void)
void serial_init (void)
int mbx8xx_console_get_configuration (void)
void _InitTQM8xx (void)
rtems_status_code bsp_register_spi (void)
void * bsp_idle_thread (uintptr_t ignored)
 Optimized idle task. More...
void cpu_init (void)
uint32_t BSP_bus_frequency
uint32_t bsp_clock_speed
 System clock frequency.
◆ bsp_idle_thread()
void * bsp_idle_thread ( uintptr_t  ignored)
This BSP provides its own IDLE thread to override the RTEMS one.
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
#include <bsp.h>
#define CONFIGURE_INIT
#define CONFIGURE_IDLE_TASK_BODY bsp_idle_thread
#include <confdefs.h>
This header file evaluates the application configuration options defined by the application.
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
#include <bsp.h>
