RTEMS 6.1-rc1
struct  mscan_context
 MSCAN context that has to be saved throughout the initialization mode. More...
#define MSCAN_BIT_RATE_MIN   10000
#define MSCAN_BIT_RATE_MAX   1000000
#define MSCAN_BIT_RATE_DEFAULT   125000
#define MSCAN_FILTER_NUMBER_MIN   0
#define MSCAN_FILTER_NUMBER_2   2
#define MSCAN_FILTER_NUMBER_4   4
#define MSCAN_FILTER_NUMBER_MAX   8
#define MSCAN_FILTER_ID_DEFAULT   0U
#define MSCAN_FILTER_MASK_DEFAULT   0xffffffffU
#define MSCAN_TRANSMIT_BUFFER_NUMBER   3
typedef struct mpc5200_mscan mscan
 MSCAN registers.
bool mscan_enable (volatile mscan *m, unsigned bit_rate)
 Enables and initializes the MSCAN module m. More...
void mscan_disable (volatile mscan *m)
 Disables the MSCAN module m. More...
void mscan_interrupts_disable (volatile mscan *m)
 Disables all interrupts for the MSCAN module m.
bool mscan_set_bit_rate (volatile mscan *m, unsigned bit_rate)
 Sets the bit rate for the MSCAN module m to can_bit_rate in [bits/s].
void mscan_initialization_mode_enter (volatile mscan *m, mscan_context *context)
 Enter initialization mode for the MSCAN module m. More...
void mscan_initialization_mode_leave (volatile mscan *m, const mscan_context *context)
 Leave initialization mode for the MSCAN module m. More...
void mscan_sleep_mode_enter (volatile mscan *m)
 Enter sleep mode for the MSCAN module m.
void mscan_sleep_mode_leave (volatile mscan *m)
 Leave sleep mode for the MSCAN module m.
volatile uint8_t * mscan_id_acceptance_register (volatile mscan *m, unsigned i)
 Returns the address of the CANIDAR register with index i of the MSCAN module m. More...
volatile uint8_t * mscan_id_mask_register (volatile mscan *m, unsigned i)
 Returns the address of the CANIDMR register with index i of the MSCAN module m. More...
unsigned mscan_filter_number (volatile mscan *m)
 Returns the number of active filters of the MSCAN module m. More...
bool mscan_set_filter_number (volatile mscan *m, unsigned number)
 Sets the number of active filters of the MSCAN module m to number and returns true if number is valid. More...
bool mscan_filter_operation (volatile mscan *m, bool set, unsigned index, uint32_t *id, uint32_t *mask)
 Sets or gets the filter ID and mask in id and mask depending on set of MSCAN module m. The filter is selected by the value of index. More...
void mscan_filter_clear (volatile mscan *m)
 Sets the filter ID and mask registers of the MSCAN module m to default values.
void mscan_get_error_counters (volatile mscan *m, unsigned *rec, unsigned *tec)
 Returns the receiver and transmitter error counter values in rec and tec of MSCAN module m.
MSCAN Control Register 0 (CANCTL0)
#define CTL0_RXFRM   (1 << 7)
#define CTL0_RXACT   (1 << 6)
#define CTL0_CSWAI   (1 << 5)
#define CTL0_SYNCH   (1 << 4)
#define CTL0_TIME   (1 << 3)
#define CTL0_WUPE   (1 << 2)
#define CTL0_SLPRQ   (1 << 1)
#define CTL0_INITRQ   (1 << 0)
MSCAN Control Register 1 (CANCTL1)
#define CTL1_CANE   (1 << 7)
#define CTL1_CLKSRC   (1 << 6)
#define CTL1_LOOPB   (1 << 5)
#define CTL1_LISTEN   (1 << 4)
#define CTL1_WUPM   (1 << 2)
#define CTL1_SLPAK   (1 << 1)
#define CTL1_INITAK   (1 << 0)
MSCAN Bus Timing Register 0 (CANBTR0)
#define BTR0_SJW_MASK   0xc0
#define BTR0_BRP_MASK   0x3f
#define BTR0_SJW(btr0)   ((btr0) << 6)
#define BTR0_BRP(btr0)   ((btr0) << 0)
#define BTR0_GET_SJW(btr0)   (((btr0) & BTR0_SJW_MASK) >> 6)
#define BTR0_GET_BRP(btr0)   (((btr0) & BTR0_BRP_MASK) >> 0)
MSCAN Bus Timing Register 1 (CANBTR1)
#define BTR1_SAMP_MASK   0x80
#define BTR1_TSEG1_MASK   0x0f
#define BTR1_TSEG2_MASK   0x70
#define BTR1_SAMP   (1 << 7)
#define BTR1_TSEG1(btr1)   ((btr1) << 0)
#define BTR1_TSEG2(btr1)   ((btr1) << 4)
#define BTR1_GET_TSEG1(btr0)   (((btr0) & BTR1_TSEG1_MASK) >> 0)
#define BTR1_GET_TSEG2(btr0)   (((btr0) & BTR1_TSEG2_MASK) >> 4)
MSCAN Receiver Flag Register (CANRFLG)
#define RFLG_WUPIF   (1 << 7)
#define RFLG_CSCIF   (1 << 6)
#define RFLG_RSTAT_MASK   (3 << 4)
#define RFLG_RSTAT_OK   (0 << 4)
#define RFLG_RSTAT_WRN   (1 << 4)
#define RFLG_RSTAT_ERR   (2 << 4)
#define RFLG_RSTAT_OFF   (3 << 4)
#define RFLG_TSTAT_MASK   (3 << 2)
#define RFLG_TSTAT_OK   (0 << 2)
#define RFLG_TSTAT_WRN   (1 << 2)
#define RFLG_TSTAT_ERR   (2 << 2)
#define RFLG_TSTAT_OFF   (3 << 2)
#define RFLG_OVRIF   (1 << 1)
#define RFLG_RXF   (1 << 0)
#define RFLG_GET_RX_STATE(rflg)   (((rflg) >> 4) & 0x03)
#define RFLG_GET_TX_STATE(rflg)   (((rflg) >> 2) & 0x03)
MSCAN Receiver Interrupt Enable Register (CANRIER)
#define RIER_WUPIE   (1 << 7)
#define RIER_CSCIE   (1 << 6)
#define RIER_RSTAT(rier)   ((rier) << 4)
#define RIER_TSTAT(rier)   ((rier) << 2)
#define RIER_OVRIE   (1 << 1)
#define RIER_RXFIE   (1 << 0)
MSCAN Transmitter Flag Register (CANTFLG)
#define TFLG_TXE2   (1 << 2)
#define TFLG_TXE1   (1 << 1)
#define TFLG_TXE0   (1 << 0)
MSCAN Transmitter Interrupt Enable Register (CANTIER)
#define TIER_TXEI2   (1 << 2)
#define TIER_TXEI1   (1 << 1)
#define TIER_TXEI0   (1 << 0)
MSCAN Transmitter Message Abort Request (CANTARQ)
#define TARQ_ABTRQ2   (1 << 2)
#define TARQ_ABTRQ1   (1 << 1)
#define TARQ_ABTRQ0   (1 << 0)
MSCAN Transmitter Message Abort Acknoledge (CANTAAK)
#define TAAK_ABTRQ2   (1 << 2)
#define TAAK_ABTRQ1   (1 << 1)
#define TAAK_ABTRQ0   (1 << 0)
MSCAN Transmit Buffer Selection (CANBSEL)
#define BSEL_TX2   (1 << 2)
#define BSEL_TX1   (1 << 1)
#define BSEL_TX0   (1 << 0)
MSCAN ID Acceptance Control Register (CANIDAC)
#define IDAC_IDAM1   (1 << 5)
#define IDAC_IDAM0   (1 << 4)
#define IDAC_IDAM   (IDAC_IDAM1 | IDAC_IDAM0)
#define IDAC_IDHIT(idac)   ((idac) & 0x7)
◆ mscan_disable()
void mscan_disable ( volatile mscan m)
The module is set to sleep mode and disabled afterwards.
◆ mscan_enable()
bool mscan_enable ( volatile mscan m,
unsigned  bit_rate
The module is set to listen only mode.
◆ mscan_filter_number()
unsigned mscan_filter_number ( volatile mscan m)
See also
MSCAN_FILTER_NUMBER_MIN, MSCAN_FILTER_NUMBER_2, MSCAN_FILTER_NUMBER_4 and MSCAN_FILTER_NUMBER_MAX.
◆ mscan_filter_operation()
bool mscan_filter_operation ( volatile mscan m,
bool  set,
unsigned  index,
uint32_t *  id,
uint32_t *  mask
Returns true if the operation was successful.
◆ mscan_id_acceptance_register()
volatile uint8_t * mscan_id_acceptance_register ( volatile mscan m,
unsigned  i
Warning
The index i is not checked if it is in range.
◆ mscan_id_mask_register()
volatile uint8_t * mscan_id_mask_register ( volatile mscan m,
unsigned  i
Warning
◆ mscan_initialization_mode_enter()
void mscan_initialization_mode_enter ( volatile mscan m,
mscan_context context
Saves the current MSCAN context in context.
◆ mscan_initialization_mode_leave()
void mscan_initialization_mode_leave ( volatile mscan m,
const mscan_context context
Saves the previous MSCAN context saved in context.
◆ mscan_set_filter_number()
bool mscan_set_filter_number ( volatile mscan m,
unsigned  number
See also
