MVME162 Board Support Package.
More...
file | bsp.h |
| Global BSP definitions.
#define | mcchip ((mcchip_regs * const) 0xFFF42000) |
#define | TX_BUFFER_EMPTY 0x04 |
#define | RX_DATA_AVAILABLE 0x01 |
#define | SCC_VECTOR 0x40 |
#define | scc ((scc_regs * const) 0xFFF45000) |
#define | ZWRITE0(port, v) (scc[port].csr = (unsigned char)(v)) |
#define | ZREAD0(port) (scc[port].csr) |
#define | ZREAD(port, n) (ZWRITE0(port, n), (scc[port].csr)) |
#define | ZREADD(port) (scc[port].csr=0x08, scc[port].csr ) |
#define | ZWRITE(port, n, v) (ZWRITE0(port, n), ZWRITE0(port, v)) |
#define | ZWRITED(port, v) |
#define | EXTERN extern |
#define | MOT_162BUG_VEC_ADDRESS 0x00000000 |
#define | memc040_1 ((memc040_regs * const) 0xFFF43000) |
#define | memc040_2 ((memc040_regs * const) 0xFFF43100) |
#define | cd2401 ((cd2401_regs * const) 0xFFF45000) |
#define | CD2401_CLK_RATE 20000000 |
MVME167 Board Support Package.
◆ ZWRITED
#define ZWRITED |
port, |
v |
Value:
scc[port].csr = (
unsigned char)(
v))
Definition: 8xx_immap.h:306
unsigned v
Definition: tte.h:0
◆ set_vector()
Install an interrupt handler.
This method installs an interrupt handle.
- Parameters
[in] | handler | is the isr routine |
[in] | vector | is the vector number |
[in] | type | indicates whether RTEMS or RAW intr |
- Returns
- returns old vector
