RTEMS 6.1-rc1
Motorola 68340 Board Support Package. More...
Files | |
file | bsp.h |
Global BSP definitions. | |
rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
Install an interrupt handler. More... | |
int | dbug_in_char (int minor) |
void | dbug_out_char (int minor, int ch) |
int | dbug_char_present (int minor) |
void | _dbug_dumpanic (void) |
void | _Init68340 (void) |
rtems_isr_entry | M68Kvec [] |
rtems_isr_entry set_vector | ( | rtems_isr_entry | handler, |
rtems_vector_number | vector, | ||
int | type | ||
This method installs an interrupt handle.
[in] | handler | is the isr routine |
[in] | vector | is the vector number |
[in] | type | indicates whether RTEMS or RAW intr |
