RTEMS 6.1-rc1
LM32 EVR Board Support Package. More...
Files | |
file | bsp.h |
Global BSP definitions. | |
rtems_isr_entry | set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type) |
Install an interrupt handler. More... | |
void | BSP_uart_polled_write (char ch) |
int | BSP_uart_polled_read (void) |
char | BSP_uart_is_character_ready (char *ch) |
rtems_isr_entry set_vector | ( | rtems_isr_entry | handler, |
rtems_vector_number | vector, | ||
int | type | ||
This method installs an interrupt handle.
[in] | handler | is the isr routine |
[in] | vector | is the vector number |
[in] | type | indicates whether RTEMS or RAW intr |
