RTEMS 6.1-rc1
This group contains the GR740 I/0 and PLL Configuration interfaces. More...
Modules | |
Alternative function enable register (ALTFUNC) | |
This group contains register bit definitions. | |
Configuration lockdown register (LOCKDOWN) | |
Drive strength configuration register 1 (DRVSTR1) | |
Drive strength configuration register 2 (DRVSTR2) | |
FTMCTRL function enable register (FTMFUNC) | |
LVDS and memory clock pad enable register (LVDSMCLK) | |
PLL current configuration register (PLLCURCFG) | |
PLL new configuration register (PLLNEWCFG) | |
PLL reconfigure command register (PLLRECFG) | |
Files | |
file | gr740-iopll-regs.h |
This header file defines the GR740 I/O and PLL configuration register block interface. | |
struct | gr740_iopll |
This structure defines the GR740 I/0 and PLL Configuration register block memory map. More... | |
Typedefs | |
typedef struct gr740_iopll | gr740_iopll |
This structure defines the GR740 I/0 and PLL Configuration register block memory map. | |
