RTEMS 6.1-rc1
NXP LPC32XX Board Support Package. More...
Modules | |
Boot Support | |
Boot support. | |
Clock Support | |
Clock support. | |
DMA Support | |
DMA support. | |
EMC Support | |
EMC Support. | |
Ethernet Support | |
Ethernet support. | |
HSU Support | |
HSU Support. | |
I2C Support | |
I2C Support. | |
I2S Support | |
I2S support. | |
Interrupt Support | |
LCD Support | |
LCD support. | |
MMU Support | |
MMU support. | |
NAND MLC Controller | |
NAND MLC Controller. | |
Register Definitions | |
Register definitions. | |
Timer Support | |
Timer support. | |
Files | |
file | console-config.c |
Console configuration. | |
file | hsu.c |
High speed UART driver (14-clock). | |
file | bsp.h |
Global BSP definitions. | |
file | nand-select.c |
NAND controller selection. | |
file | rtc-config.c |
RTC configuration. | |
file | bspidle.c |
bsp_idle_thread() implementation. | |
file | bspreset.c |
Reset code. | |
file | bspstart.c |
Startup code. | |
file | bspstarthooks.c |
Startup code. | |
file | restart.c |
Restart implementation. | |
file | system-clocks.c |
System clocks. | |
file | timer.c |
Benchmark timer support. | |
#define | BSP_FEATURE_IRQ_EXTENSION |
#define | RTEMS_BSP_NETWORK_DRIVER_ATTACH lpc_eth_attach_detach |
Standard network driver attach and detach function. | |
#define | RTEMS_BSP_NETWORK_DRIVER_NAME "eth0" |
Standard network driver name. | |
#define | LPC32XX_STANDARD_TIMER (&lpc32xx.timer_1) |
#define | BSP_IDLE_TASK_BODY bsp_idle_thread |
#define | BSP_CONSOLE_UART_BASE LPC32XX_BASE_UART_5 |
#define | LPC32XX_DO_STOP_GPDMA |
#define | LPC32XX_DO_STOP_ETHERNET |
#define | LPC32XX_DO_STOP_USB |
#define | LPC32XX_DO_RESTART(addr) |
Enumerations | |
enum | lpc32xx_nand_controller { LPC32XX_NAND_CONTROLLER_NONE , LPC32XX_NAND_CONTROLLER_MLC , LPC32XX_NAND_CONTROLLER_SLC } |
int | lpc_eth_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching) |
Network driver attach and detach function. | |
void * | lpc32xx_idle (uintptr_t ignored) |
Optimized idle task. More... | |
bool | lpc32xx_start_pll_setup (uint32_t hclkpll_ctrl, uint32_t hclkdiv_ctrl, bool force) |
uint32_t | lpc32xx_sysclk (void) |
uint32_t | lpc32xx_hclkpll_clk (void) |
uint32_t | lpc32xx_periph_clk (void) |
uint32_t | lpc32xx_hclk (void) |
uint32_t | lpc32xx_arm_clk (void) |
uint32_t | lpc32xx_ddram_clk (void) |
void | lpc32xx_select_nand_controller (lpc32xx_nand_controller nand_controller) |
void | bsp_restart (void *addr) |
void * | bsp_idle_thread (uintptr_t arg) |
uint32_t | lpc32xx_magic_zero_begin [] |
Begin of magic zero area. More... | |
uint32_t | lpc32xx_magic_zero_end [] |
End of magic zero area. More... | |
uint32_t | lpc32xx_magic_zero_size [] |
Size of magic zero area. More... | |
#define LPC32XX_DO_RESTART | ( | addr | ) |
#define LPC32XX_DO_STOP_ETHERNET |
#define LPC32XX_DO_STOP_GPDMA |
#define LPC32XX_DO_STOP_USB |
void * bsp_idle_thread | ( | uintptr_t | ignored | ) |
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
void * lpc32xx_idle | ( | uintptr_t | ignored | ) |
extern |
A read from this area returns zero. Writes have no effect.
extern |
extern |
