RTEMS 6.1-rc1
#define | __HAL_RTC_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_RTC_STATE_RESET) |
Reset RTC handle state. More... | |
#define | __HAL_RTC_WRITEPROTECTION_DISABLE(__HANDLE__) |
Disable the write protection for RTC registers. More... | |
#define | __HAL_RTC_WRITEPROTECTION_ENABLE(__HANDLE__) |
Enable the write protection for RTC registers. More... | |
#define | __HAL_RTC_IS_CALENDAR_INITIALIZED(__HANDLE__) (((((__HANDLE__)->Instance->ISR) & (RTC_FLAG_INITS)) == RTC_FLAG_INITS) ? 1U : 0U) |
Check whether the RTC Calendar is initialized. More... | |
#define | __HAL_RTC_DAYLIGHT_SAVING_TIME_ADD1H(__HANDLE__, __BKP__) |
Add 1 hour (summer time change). More... | |
#define | __HAL_RTC_DAYLIGHT_SAVING_TIME_SUB1H(__HANDLE__, __BKP__) |
Subtract 1 hour (winter time change). More... | |
#define | __HAL_RTC_ALARMA_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR |= (RTC_CR_ALRAE)) |
Enable the RTC ALARMA peripheral. More... | |
#define | __HAL_RTC_ALARMA_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR &= ~(RTC_CR_ALRAE)) |
Disable the RTC ALARMA peripheral. More... | |
#define | __HAL_RTC_ALARMB_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR |= (RTC_CR_ALRBE)) |
Enable the RTC ALARMB peripheral. More... | |
#define | __HAL_RTC_ALARMB_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR &= ~(RTC_CR_ALRBE)) |
Disable the RTC ALARMB peripheral. More... | |
#define | __HAL_RTC_ALARM_ENABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR |= (__INTERRUPT__)) |
Enable the RTC Alarm interrupt. More... | |
#define | __HAL_RTC_ALARM_DISABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR &= ~(__INTERRUPT__)) |
Disable the RTC Alarm interrupt. More... | |
#define | __HAL_RTC_ALARM_GET_IT(__HANDLE__, __INTERRUPT__) (((((__HANDLE__)->Instance->ISR)& (__INTERRUPT__ >> 4)) != 0U)? 1U : 0U) |
Check whether the specified RTC Alarm interrupt has occurred or not. More... | |
#define | __HAL_RTC_ALARM_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) (((((__HANDLE__)->Instance->CR) & (__INTERRUPT__)) != 0U) ? 1U : 0U) |
Check whether the specified RTC Alarm interrupt has been enabled or not. More... | |
#define | __HAL_RTC_ALARM_GET_FLAG(__HANDLE__, __FLAG__) (((((__HANDLE__)->Instance->ISR) & (__FLAG__)) != 0U) ? 1U : 0U) |
Get the selected RTC Alarm's flag status. More... | |
#define | __HAL_RTC_ALARM_CLEAR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->ISR = (~((__FLAG__) | RTC_ISR_INIT)|((__HANDLE__)->Instance->ISR & RTC_ISR_INIT))) |
Clear the RTC Alarm's pending flags. More... | |
#define | __HAL_RTC_ALARM_EXTI_ENABLE_IT() (EXTI->IMR1 |= RTC_EXTI_LINE_ALARM_EVENT) |
Enable interrupt on the RTC Alarm associated Exti line. More... | |
#define | __HAL_RTC_ALARM_EXTI_DISABLE_IT() (EXTI->IMR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT)) |
Disable interrupt on the RTC Alarm associated Exti line. More... | |
#define | __HAL_RTC_ALARM_EXTI_ENABLE_EVENT() (EXTI->EMR1 |= RTC_EXTI_LINE_ALARM_EVENT) |
Enable event on the RTC Alarm associated Exti line. More... | |
#define | __HAL_RTC_ALARM_EXTI_DISABLE_EVENT() (EXTI->EMR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT)) |
Disable event on the RTC Alarm associated Exti line. More... | |
#define | __HAL_RTC_ALARM_EXTI_ENABLE_FALLING_EDGE() (EXTI->FTSR1 |= RTC_EXTI_LINE_ALARM_EVENT) |
Enable falling edge trigger on the RTC Alarm associated Exti line. More... | |
#define | __HAL_RTC_ALARM_EXTI_DISABLE_FALLING_EDGE() (EXTI->FTSR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT)) |
Disable falling edge trigger on the RTC Alarm associated Exti line. More... | |
#define | __HAL_RTC_ALARM_EXTI_ENABLE_RISING_EDGE() (EXTI->RTSR1 |= RTC_EXTI_LINE_ALARM_EVENT) |
Enable rising edge trigger on the RTC Alarm associated Exti line. More... | |
#define | __HAL_RTC_ALARM_EXTI_DISABLE_RISING_EDGE() (EXTI->RTSR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT)) |
Disable rising edge trigger on the RTC Alarm associated Exti line. More... | |
#define | __HAL_RTC_ALARM_EXTI_ENABLE_RISING_FALLING_EDGE() |
Enable rising & falling edge trigger on the RTC Alarm associated Exti line. More... | |
#define | __HAL_RTC_ALARM_EXTI_DISABLE_RISING_FALLING_EDGE() |
Disable rising & falling edge trigger on the RTC Alarm associated Exti line. More... | |
#define | __HAL_RTC_ALARM_EXTI_GET_FLAG() (EXTI->PR1 & RTC_EXTI_LINE_ALARM_EVENT) |
Check whether the RTC Alarm associated Exti line interrupt flag is set or not. More... | |
#define | __HAL_RTC_ALARM_EXTI_CLEAR_FLAG() (EXTI->PR1 = (RTC_EXTI_LINE_ALARM_EVENT)) |
Clear the RTC Alarm associated Exti line flag. More... | |
#define | __HAL_RTC_ALARM_EXTI_GENERATE_SWIT() (EXTI->SWIER1 |= RTC_EXTI_LINE_ALARM_EVENT) |
Generate a Software interrupt on RTC Alarm associated Exti line. More... | |
#define __HAL_RTC_ALARM_CLEAR_FLAG | ( | __HANDLE__, | |
__FLAG__ | |||
) | ((__HANDLE__)->Instance->ISR = (~((__FLAG__) | RTC_ISR_INIT)|((__HANDLE__)->Instance->ISR & RTC_ISR_INIT))) |
__HANDLE__ | specifies the RTC handle. |
__FLAG__ | specifies the RTC Alarm Flag sources to clear. This parameter can be:
None |
#define __HAL_RTC_ALARM_DISABLE_IT | ( | __HANDLE__, | |
__INTERRUPT__ | |||
) | ((__HANDLE__)->Instance->CR &= ~(__INTERRUPT__)) |
__INTERRUPT__ | specifies the RTC Alarm interrupt sources to be enabled or disabled. This parameter can be any combination of the following values:
None |
#define __HAL_RTC_ALARM_ENABLE_IT | ( | __HANDLE__, | |
__INTERRUPT__ | |||
) | ((__HANDLE__)->Instance->CR |= (__INTERRUPT__)) |
None |
#define __HAL_RTC_ALARM_EXTI_CLEAR_FLAG | ( | ) | (EXTI->PR1 = (RTC_EXTI_LINE_ALARM_EVENT)) |
None. |
#define __HAL_RTC_ALARM_EXTI_DISABLE_EVENT | ( | ) | (EXTI->EMR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT)) |
None. |
#define __HAL_RTC_ALARM_EXTI_DISABLE_FALLING_EDGE | ( | ) | (EXTI->FTSR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT)) |
None |
#define __HAL_RTC_ALARM_EXTI_DISABLE_IT | ( | ) | (EXTI->IMR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT)) |
None |
#define __HAL_RTC_ALARM_EXTI_DISABLE_RISING_EDGE | ( | ) | (EXTI->RTSR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT)) |
None |
#define __HAL_RTC_ALARM_EXTI_DISABLE_RISING_FALLING_EDGE | ( | ) |
None |
#define __HAL_RTC_ALARM_EXTI_ENABLE_EVENT | ( | ) | (EXTI->EMR1 |= RTC_EXTI_LINE_ALARM_EVENT) |
None. |
#define __HAL_RTC_ALARM_EXTI_ENABLE_FALLING_EDGE | ( | ) | (EXTI->FTSR1 |= RTC_EXTI_LINE_ALARM_EVENT) |
None |
#define __HAL_RTC_ALARM_EXTI_ENABLE_IT | ( | ) | (EXTI->IMR1 |= RTC_EXTI_LINE_ALARM_EVENT) |
None |
#define __HAL_RTC_ALARM_EXTI_ENABLE_RISING_EDGE | ( | ) | (EXTI->RTSR1 |= RTC_EXTI_LINE_ALARM_EVENT) |
None |
#define __HAL_RTC_ALARM_EXTI_ENABLE_RISING_FALLING_EDGE | ( | ) |
None |
#define __HAL_RTC_ALARM_EXTI_GENERATE_SWIT | ( | ) | (EXTI->SWIER1 |= RTC_EXTI_LINE_ALARM_EVENT) |
None |
#define __HAL_RTC_ALARM_EXTI_GET_FLAG | ( | ) | (EXTI->PR1 & RTC_EXTI_LINE_ALARM_EVENT) |
Line | Status. |
#define __HAL_RTC_ALARM_GET_FLAG | ( | __HANDLE__, | |
__FLAG__ | |||
) | (((((__HANDLE__)->Instance->ISR) & (__FLAG__)) != 0U) ? 1U : 0U) |
__FLAG__ | specifies the RTC Alarm Flag sources to check. This parameter can be:
None |
#define __HAL_RTC_ALARM_GET_IT | ( | __HANDLE__, | |
__INTERRUPT__ | |||
) | (((((__HANDLE__)->Instance->ISR)& (__INTERRUPT__ >> 4)) != 0U)? 1U : 0U) |
__INTERRUPT__ | specifies the RTC Alarm interrupt sources to check. This parameter can be:
None |
#define __HAL_RTC_ALARM_GET_IT_SOURCE | ( | __HANDLE__, | |
__INTERRUPT__ | |||
) | (((((__HANDLE__)->Instance->CR) & (__INTERRUPT__)) != 0U) ? 1U : 0U) |
None |
#define __HAL_RTC_ALARMA_DISABLE | ( | __HANDLE__ | ) | ((__HANDLE__)->Instance->CR &= ~(RTC_CR_ALRAE)) |
None |
#define __HAL_RTC_ALARMA_ENABLE | ( | __HANDLE__ | ) | ((__HANDLE__)->Instance->CR |= (RTC_CR_ALRAE)) |
None |
#define __HAL_RTC_ALARMB_DISABLE | ( | __HANDLE__ | ) | ((__HANDLE__)->Instance->CR &= ~(RTC_CR_ALRBE)) |
None |
#define __HAL_RTC_ALARMB_ENABLE | ( | __HANDLE__ | ) | ((__HANDLE__)->Instance->CR |= (RTC_CR_ALRBE)) |
None |
#define __HAL_RTC_DAYLIGHT_SAVING_TIME_ADD1H | ( | __HANDLE__, | |
__BKP__ | |||
__BKP__ | Backup This parameter can be:
None |
#define __HAL_RTC_DAYLIGHT_SAVING_TIME_SUB1H | ( | __HANDLE__, | |
__BKP__ | |||
None |
#define __HAL_RTC_IS_CALENDAR_INITIALIZED | ( | __HANDLE__ | ) | (((((__HANDLE__)->Instance->ISR) & (RTC_FLAG_INITS)) == RTC_FLAG_INITS) ? 1U : 0U) |
None |
#define __HAL_RTC_RESET_HANDLE_STATE | ( | __HANDLE__ | ) | ((__HANDLE__)->State = HAL_RTC_STATE_RESET) |
__HANDLE__ | RTC handle. |
None |
#define __HAL_RTC_WRITEPROTECTION_DISABLE | ( | __HANDLE__ | ) |
None |
#define __HAL_RTC_WRITEPROTECTION_ENABLE | ( | __HANDLE__ | ) |
None |
