#define | __HAL_RAMECC_ENABLE_GLOBAL_IT(__HANDLE__, __INTERRUPT__) ((((RAMECC_TypeDef *)((uint32_t)(__HANDLE__)->Instance & 0xFFFFFF00U))->IER) |= ((__INTERRUPT__) & ~RAMECC_IT_GLOBAL_ID)) |
#define | __HAL_RAMECC_ENABLE_MONITOR_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR |= ((__INTERRUPT__) & ~RAMECC_IT_MONITOR_ID)) |
#define | __HAL_RAMECC_ENABLE_IT(__HANDLE__, __INTERRUPT__) |
| Enable the specified RAMECC interrupts. More...
#define | __HAL_RAMECC_DISABLE_GLOBAL_IT(__HANDLE__, __INTERRUPT__) ((((RAMECC_TypeDef *)((uint32_t)(__HANDLE__)->Instance & 0xFFFFFF00U))->IER) &= ~((__INTERRUPT__) & ~RAMECC_IT_GLOBAL_ID)) |
#define | __HAL_RAMECC_DISABLE_MONITOR_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR &= ~((__INTERRUPT__) & ~RAMECC_IT_MONITOR_ID)) |
#define | __HAL_RAMECC_DISABLE_IT(__HANDLE__, __INTERRUPT__) |
| Disable the specified RAMECC interrupts. More...
#define | __HAL_RAMECC_GET_GLOBAL_IT_SOURCE(__HANDLE__, __INTERRUPT__) (((((RAMECC_TypeDef *)((uint32_t)(__HANDLE__)->Instance & 0xFFFFFF00U))->IER) & ((__INTERRUPT__) & ~RAMECC_IT_GLOBAL_ID)) ? SET : RESET) |
#define | __HAL_RAMECC_GET_MONITOR_IT_SOURCE(__HANDLE__, __INTERRUPT__) ((((__HANDLE__)->Instance->CR) & ((__INTERRUPT__) & ~RAMECC_IT_GLOBAL_ID)) ? SET : RESET) |
#define | __HAL_RAMECC_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) |
| Check whether the specified RAMECC interrupt source is enabled or not. More...
#define | __HAL_RAMECC_GET_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->SR &= (__FLAG__)) |
| Get the RAMECC pending flags. More...
#define | __HAL_RAMECC_CLEAR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->SR &= ~(__FLAG__)) |
| Clear the RAMECC pending flags. More...
#define | __HAL_RAMECC_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_RAMECC_STATE_RESET) |
| Reset the RAMECC handle state. More...
