RTEMS 6.1-rc1
Files | Macros | Functions
POSIX Priority Support
Interface to the POSIX Priority Implementation. More...
file  psxpriorityisvalid.c
 POSIX Is Priority Valid.
#define POSIX_SCHEDULER_MINIMUM_PRIORITY   (1)
Priority_Control _POSIX_Priority_To_core (const Scheduler_Control *scheduler, int priority, bool *valid)
 Converts the POSIX API priority to the corresponding SuperCore priority and validates it. More...
int _POSIX_Priority_From_core (const Scheduler_Control *scheduler, Priority_Control priority)
 Converts the SuperCore priority to the corresponding POSIX API priority. More...
◆ POSIX_SCHEDULER_MINIMUM_PRIORITY
This is the numerically least important POSIX priority.
◆ _POSIX_Priority_From_core()
int _POSIX_Priority_From_core ( const Scheduler_Control scheduler,
Parameters
[in]schedulerThe scheduler instance.
[in]priorityThe SuperCore priority to convert.
Returns
The corresponding POSIX API priority.
◆ _POSIX_Priority_To_core()
Priority_Control _POSIX_Priority_To_core ( const Scheduler_Control scheduler,
int  priority,
bool *  valid
According to POSIX, numerically higher values represent higher priorities. Thus, SuperCore has priorities run in the opposite sense of the POSIX API.
Let N be the maximum priority of this scheduler instance. The SuperCore priority zero is system reserved (PRIORITY_MINIMUM). There are only N - 1 POSIX API priority levels since a thread at SuperCore priority N would never run because of the idle threads. This is necessary because GNAT maps the lowest Ada task priority to the lowest thread priority. The lowest priority Ada task should get to run, so there is a fundamental conflict with having N priorities.
Parameters
[in]priorityThe POSIX API priority to convert and validate.
[out]validIndicates if the POSIX API priority is valid and a corresponding SuperCore priority in the specified scheduler instance exists.
Returns
The corresponding SuperCore priority.
