RTEMS 6.1-rc1
macros to handle NAND device enable/disable More...
#define __FMC_NAND_ENABLE(__INSTANCE__)   ((__INSTANCE__)->PCR |= FMC_PCR_PBKEN)
 Enable the NAND device access. More...
#define __FMC_NAND_DISABLE(__INSTANCE__, __BANK__)   CLEAR_BIT((__INSTANCE__)->PCR, FMC_PCR_PBKEN)
 Disable the NAND device access. More...
◆ __FMC_NAND_DISABLE
#define __FMC_NAND_DISABLE (   __INSTANCE__,
  __BANK__
Parameters
__INSTANCE__FMC_NAND Instance
__BANK__FMC_NAND Bank
Return values
None
◆ __FMC_NAND_ENABLE
#define __FMC_NAND_ENABLE (   __INSTANCE__)    ((__INSTANCE__)->PCR |= FMC_PCR_PBKEN)
Parameters
Return values
None
