RTEMS 6.1-rc1
Typedefs | |
typedef enum ALT_DMA_CHANNEL_e | ALT_DMA_CHANNEL_t |
typedef enum ALT_DMA_PERIPH_e | ALT_DMA_PERIPH_t |
typedef enum ALT_DMA_SECURITY_e | ALT_DMA_SECURITY_t |
typedef enum ALT_DMA_EVENT_e | ALT_DMA_EVENT_t |
This module contains the common definitions for the DMA controller related APIs.
typedef enum ALT_DMA_CHANNEL_e ALT_DMA_CHANNEL_t |
This type definition enumerates the DMA controller channel threads.
typedef enum ALT_DMA_EVENT_e ALT_DMA_EVENT_t |
This type definition enumerates the DMA event-interrupt resources.
typedef enum ALT_DMA_PERIPH_e ALT_DMA_PERIPH_t |
This type definition enumerates the SoC system peripherals implementing the required request interface that enables direct DMA transfers to/from the device.
FPGA soft IP interface to the DMA are required to comply with the Synopsys protocol.
Request interface numbers 4 through 7 are multiplexed between the CAN controllers and soft logic implemented in the FPGA fabric. The selection between the CAN controller and FPGA interfaces is determined at DMA initialization.
typedef enum ALT_DMA_SECURITY_e ALT_DMA_SECURITY_t |
This type enumerates the DMA security state options available.
