12#include "fsl_common.h"
14#if (defined(FSL_FEATURE_MEMORY_HAS_ADDRESS_OFFSET) && (0 != FSL_FEATURE_MEMORY_HAS_ADDRESS_OFFSET))
15#include "fsl_memory.h"
30#define FSL_ELCDIF_DRIVER_VERSION (MAKE_VERSION(2, 0, 5))
34#define ELCDIF_CTRL1_IRQ_MASK \
35 (LCDIF_CTRL1_BM_ERROR_IRQ_MASK | LCDIF_CTRL1_OVERFLOW_IRQ_MASK | LCDIF_CTRL1_UNDERFLOW_IRQ_MASK | \
36 LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_MASK | LCDIF_CTRL1_VSYNC_EDGE_IRQ_MASK)
39#define ELCDIF_CTRL1_IRQ_EN_MASK \
40 (LCDIF_CTRL1_BM_ERROR_IRQ_EN_MASK | LCDIF_CTRL1_OVERFLOW_IRQ_EN_MASK | LCDIF_CTRL1_UNDERFLOW_IRQ_EN_MASK | \
41 LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN_MASK | LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN_MASK)
44#if defined(LCDIF_AS_CTRL_CSI_SYNC_ON_IRQ_MASK)
45#define ELCDIF_AS_CTRL_IRQ_MASK (LCDIF_AS_CTRL_CSI_SYNC_ON_IRQ_MASK)
47#define ELCDIF_AS_CTRL_IRQ_MASK 0U
51#if defined(LCDIF_AS_CTRL_CSI_SYNC_ON_IRQ_EN_MASK)
52#define ELCDIF_AS_CTRL_IRQ_EN_MASK (LCDIF_AS_CTRL_CSI_SYNC_ON_IRQ_EN_MASK)
54#define ELCDIF_AS_CTRL_IRQ_EN_MASK 0U
57#if ((0 != (ELCDIF_CTRL1_IRQ_MASK & ELCDIF_AS_CTRL_IRQ_MASK)) || \
58 (0 != (ELCDIF_AS_CTRL_IRQ_MASK & ELCDIF_AS_CTRL_IRQ_EN_MASK)))
59#error Interrupt bits overlap, need to update the interrupt functions.
62#if defined(LCDIF_CTRL_ENABLE_PXP_HANDSHAKE_MASK)
63#define FSL_FEATURE_LCDIF_HAS_PXP_HANDSHAKE 1
65#define FSL_FEATURE_LCDIF_HAS_PXP_HANDSHAKE 0
68#if (defined(FSL_FEATURE_MEMORY_HAS_ADDRESS_OFFSET) && (0 != FSL_FEATURE_MEMORY_HAS_ADDRESS_OFFSET))
69#define ELCDIF_ADDR_CPU_2_IP(addr) (MEMORY_ConvertMemoryMapAddress((uint32_t)(addr), kMEMORY_Local2DMA))
71#define ELCDIF_ADDR_CPU_2_IP(addr) (addr)
75#define ELCDIF_LUT_ENTRY_NUM 256U
105 LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN_MASK,
107 LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN_MASK,
108#if defined(LCDIF_AS_CTRL_CSI_SYNC_ON_IRQ_EN_MASK)
109 kELCDIF_SciSyncOnInterruptEnable =
110 LCDIF_AS_CTRL_CSI_SYNC_ON_IRQ_EN_MASK,
123 LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_MASK,
125#if defined(LCDIF_AS_CTRL_CSI_SYNC_ON_IRQ_MASK)
126 kELCDIF_SciSyncOn = LCDIF_AS_CTRL_CSI_SYNC_ON_IRQ_MASK,
139#if defined(LCDIF_STAT_BUSY_MASK)
140 kELCDIF_LcdControllerBusy = LCDIF_STAT_BUSY_MASK,
142#if defined(LCDIF_STAT_DVI_CURRENT_FIELD_MASK)
143 kELCDIF_CurDviField2 = LCDIF_STAT_DVI_CURRENT_FIELD_MASK,
301#if defined(__cplusplus)
375static inline void ELCDIF_RgbModeStart(
LCDIF_Type *base)
377 base->CTRL_SET = LCDIF_CTRL_RUN_MASK | LCDIF_CTRL_DOTCLK_MODE_MASK;
393static inline void ELCDIF_SetNextBufferAddr(
LCDIF_Type *base, uint32_t bufferAddr)
395 base->NEXT_BUF = ELCDIF_ADDR_CPU_2_IP(bufferAddr);
405#if !(defined(FSL_FEATURE_LCDIF_HAS_NO_RESET_PIN) && (0 != FSL_FEATURE_LCDIF_HAS_NO_RESET_PIN))
412static inline void ELCDIF_PullUpResetPin(
LCDIF_Type *base,
bool pullUp)
416 base->CTRL1_SET = LCDIF_CTRL1_RESET_MASK;
420 base->CTRL1_CLR = LCDIF_CTRL1_RESET_MASK;
425#if (defined(FSL_FEATURE_LCDIF_HAS_PXP_HANDSHAKE) && (0 != FSL_FEATURE_LCDIF_HAS_PXP_HANDSHAKE))
432static inline void ELCDIF_EnablePxpHandShake(
LCDIF_Type *base,
bool enable)
436 base->CTRL_SET = LCDIF_CTRL_ENABLE_PXP_HANDSHAKE_MASK;
440 base->CTRL_CLR = LCDIF_CTRL_ENABLE_PXP_HANDSHAKE_MASK;
463static inline uint32_t ELCDIF_GetCrcValue(
const LCDIF_Type *base)
465 return base->CRC_STAT;
478static inline uint32_t ELCDIF_GetBusMasterErrorAddr(
480 return base->BM_ERROR_STAT;
505static inline uint32_t ELCDIF_GetStatus(
507 return base->STAT & (LCDIF_STAT_LFIFO_FULL_MASK | LCDIF_STAT_LFIFO_EMPTY_MASK | LCDIF_STAT_TXFIFO_FULL_MASK |
508 LCDIF_STAT_TXFIFO_EMPTY_MASK
509#if defined(LCDIF_STAT_BUSY_MASK)
510 | LCDIF_STAT_BUSY_MASK
512#if defined(LCDIF_STAT_DVI_CURRENT_FIELD_MASK)
513 | LCDIF_STAT_DVI_CURRENT_FIELD_MASK
524static inline uint32_t ELCDIF_GetLFifoCount(
526 return (base->STAT & LCDIF_STAT_LFIFO_COUNT_MASK) >> LCDIF_STAT_LFIFO_COUNT_SHIFT;
542static inline void ELCDIF_EnableInterrupts(
LCDIF_Type *base, uint32_t mask)
544 base->CTRL1_SET = (mask & ELCDIF_CTRL1_IRQ_EN_MASK);
545#if !(defined(FSL_FEATURE_LCDIF_HAS_NO_AS) && (0 != FSL_FEATURE_LCDIF_HAS_NO_AS))
546 base->AS_CTRL |= (mask & ELCDIF_AS_CTRL_IRQ_EN_MASK);
556static inline void ELCDIF_DisableInterrupts(
558 base->CTRL1_CLR = (mask & ELCDIF_CTRL1_IRQ_EN_MASK);
559#if !(defined(FSL_FEATURE_LCDIF_HAS_NO_AS) && (0 != FSL_FEATURE_LCDIF_HAS_NO_AS))
560 base->AS_CTRL &= ~(mask & ELCDIF_AS_CTRL_IRQ_EN_MASK);
570static inline uint32_t ELCDIF_GetInterruptStatus(
574 flags = (base->CTRL1 & ELCDIF_CTRL1_IRQ_MASK);
575#if !(defined(FSL_FEATURE_LCDIF_HAS_NO_AS) && (0 != FSL_FEATURE_LCDIF_HAS_NO_AS))
576 flags |= (base->AS_CTRL & ELCDIF_AS_CTRL_IRQ_MASK);
588static inline void ELCDIF_ClearInterruptStatus(
590 base->CTRL1_CLR = (mask & ELCDIF_CTRL1_IRQ_MASK);
591#if !(defined(FSL_FEATURE_LCDIF_HAS_NO_AS) && (0 != FSL_FEATURE_LCDIF_HAS_NO_AS))
592 base->AS_CTRL &= ~(mask & ELCDIF_AS_CTRL_IRQ_MASK);
598#if !(defined(FSL_FEATURE_LCDIF_HAS_NO_AS) && (0 != FSL_FEATURE_LCDIF_HAS_NO_AS))
626static inline void ELCDIF_SetNextAlphaSurfaceBufferAddr(
628 base->AS_NEXT_BUF = ELCDIF_ADDR_CPU_2_IP(bufferAddr);
644static inline void ELCDIF_SetOverlayColorKey(
LCDIF_Type *base, uint32_t colorKeyLow, uint32_t colorKeyHigh)
646 base->AS_CLRKEYLOW = colorKeyLow;
647 base->AS_CLRKEYHIGH = colorKeyHigh;
656static inline void ELCDIF_EnableOverlayColorKey(
LCDIF_Type *base,
bool enable)
660 base->AS_CTRL |= LCDIF_AS_CTRL_ENABLE_COLORKEY_MASK;
664 base->AS_CTRL &= ~LCDIF_AS_CTRL_ENABLE_COLORKEY_MASK;
674static inline void ELCDIF_EnableAlphaSurface(
LCDIF_Type *base,
bool enable)
678 base->AS_CTRL |= LCDIF_AS_CTRL_AS_ENABLE_MASK;
682 base->AS_CTRL &= ~LCDIF_AS_CTRL_AS_ENABLE_MASK;
695static inline void ELCDIF_EnableProcessSurface(
LCDIF_Type *base,
bool enable)
699 base->AS_CTRL &= ~LCDIF_AS_CTRL_PS_DISABLE_MASK;
703 base->AS_CTRL |= LCDIF_AS_CTRL_PS_DISABLE_MASK;
710#if (defined(FSL_FEATURE_LCDIF_HAS_LUT) && (0 != FSL_FEATURE_LCDIF_HAS_LUT))
729static inline void ELCDIF_EnableLut(
LCDIF_Type *base,
bool enable)
733 base->LUT_CTRL &= ~LCDIF_LUT_CTRL_LUT_BYPASS_MASK;
737 base->LUT_CTRL |= LCDIF_LUT_CTRL_LUT_BYPASS_MASK;
761#if defined(__cplusplus)
#define LCDIF_CTRL_LCD_DATABUS_WIDTH(x)
Definition: MIMXRT1052.h:27501
uint8_t hfp
Definition: fsl_elcdif.h:197
_elcdif_status_flags
eLCDIF status flags
Definition: fsl_elcdif.h:134
elcdif_as_pixel_format_t pixelFormat
Definition: fsl_elcdif.h:228
_elcdif_as_pixel_format
eLCDIF alpha surface pixel format.
Definition: fsl_elcdif.h:212
enum _elcdif_as_pixel_format elcdif_as_pixel_format_t
uint32_t polarityFlags
Definition: fsl_elcdif.h:202
elcdif_rop_mode_t ropMode
Definition: fsl_elcdif.h:279
_elcdif_pixel_format
The pixel format.
Definition: fsl_elcdif.h:155
enum _elcdif_rop_mode elcdif_rop_mode_t
eLCDIF ROP mode during blending.
bool invertAlpha
Definition: fsl_elcdif.h:277
enum _elcdif_lut elcdif_lut_t
eLCDIF LUT
elcdif_pixel_format_t pixelFormat
Definition: fsl_elcdif.h:204
uint8_t vfp
Definition: fsl_elcdif.h:200
_elcdif_alpha_mode
eLCDIF alpha mode during blending.
Definition: fsl_elcdif.h:235
uint32_t regCtrl1
Definition: fsl_elcdif.h:186
elcdif_lcd_data_bus_t dataBus
Definition: fsl_elcdif.h:205
uint32_t bufferAddr
Definition: fsl_elcdif.h:203
_elcdif_lcd_data_bus
The LCD data bus type.
Definition: fsl_elcdif.h:166
uint8_t hsw
Definition: fsl_elcdif.h:196
uint32_t bufferAddr
Definition: fsl_elcdif.h:227
_elcdif_polarity_flags
eLCDIF signal polarity flags
Definition: fsl_elcdif.h:81
void ELCDIF_RgbModeStop(LCDIF_Type *base)
Stop display in RGB (DOTCLK) mode and wait until finished.
Definition: fsl_elcdif.c:240
struct _elcdif_as_buffer_config elcdif_as_buffer_config_t
eLCDIF alpha surface buffer configuration.
enum _elcdif_pixel_format elcdif_pixel_format_t
The pixel format.
enum _elcdif_alpha_mode elcdif_alpha_mode_t
void ELCDIF_SetAlphaSurfaceBufferConfig(LCDIF_Type *base, const elcdif_as_buffer_config_t *config)
Set the configuration for alpha surface buffer.
Definition: fsl_elcdif.c:299
struct _elcdif_rgb_mode_config elcdif_rgb_mode_config_t
eLCDIF configure structure for RGB mode (DOTCLK mode).
struct _elcdif_pixel_format_reg elcdif_pixel_format_reg_t
The register value when using different pixel format.
struct _elcdif_as_blend_config elcdif_as_blend_config_t
eLCDIF alpha surface blending configuration.
_elcdif_rop_mode
Definition: fsl_elcdif.h:255
_elcdif_interrupt_enable
The eLCDIF interrupts to enable.
Definition: fsl_elcdif.h:100
void ELCDIF_RgbModeInit(LCDIF_Type *base, const elcdif_rgb_mode_config_t *config)
Initializes the eLCDIF to work in RGB mode (DOTCLK mode).
Definition: fsl_elcdif.c:101
uint16_t panelHeight
Definition: fsl_elcdif.h:195
_elcdif_interrupt_flags
The eLCDIF interrupt status flags.
Definition: fsl_elcdif.h:118
void ELCDIF_Deinit(LCDIF_Type *base)
Deinitializes the eLCDIF peripheral.
Definition: fsl_elcdif.c:221
uint16_t panelWidth
Definition: fsl_elcdif.h:194
elcdif_alpha_mode_t alphaMode
Definition: fsl_elcdif.h:278
void ELCDIF_SetAlphaSurfaceBlendConfig(LCDIF_Type *base, const elcdif_as_blend_config_t *config)
Set the alpha surface blending configuration.
Definition: fsl_elcdif.c:314
enum _elcdif_lcd_data_bus elcdif_lcd_data_bus_t
void ELCDIF_RgbModeSetPixelFormat(LCDIF_Type *base, elcdif_pixel_format_t pixelFormat)
Set the pixel format in RGB (DOTCLK) mode.
Definition: fsl_elcdif.c:205
uint8_t hbp
Definition: fsl_elcdif.h:198
uint32_t regCtrl
Definition: fsl_elcdif.h:185
uint8_t vbp
Definition: fsl_elcdif.h:201
uint8_t vsw
Definition: fsl_elcdif.h:199
void ELCDIF_Reset(LCDIF_Type *base)
Reset the eLCDIF peripheral.
Definition: fsl_elcdif.c:255
void ELCDIF_RgbModeGetDefaultConfig(elcdif_rgb_mode_config_t *config)
Gets the eLCDIF default configuration structure for RGB (DOTCLK) mode.
Definition: fsl_elcdif.c:177
_elcdif_lut
eLCDIF LUT
Definition: fsl_elcdif.h:292
uint8_t alpha
Definition: fsl_elcdif.h:275
@ kELCDIF_TxFifoEmpty
Definition: fsl_elcdif.h:138
@ kELCDIF_TxFifoFull
Definition: fsl_elcdif.h:137
@ kELCDIF_LFifoEmpty
Definition: fsl_elcdif.h:136
@ kELCDIF_LFifoFull
Definition: fsl_elcdif.h:135
@ kELCDIF_AsPixelFormatARGB1555
Definition: fsl_elcdif.h:215
@ kELCDIF_AsPixelFormatARGB8888
Definition: fsl_elcdif.h:213
@ kELCDIF_AsPixelFormatRGB444
Definition: fsl_elcdif.h:218
@ kELCDIF_AsPixelFormatRGB565
Definition: fsl_elcdif.h:219
@ kELCDIF_AsPixelFormatRGB888
Definition: fsl_elcdif.h:214
@ kELCDIF_AsPixelFormatARGB4444
Definition: fsl_elcdif.h:216
@ kELCDIF_AsPixelFormatRGB555
Definition: fsl_elcdif.h:217
@ kELCDIF_PixelFormatRGB666
Definition: fsl_elcdif.h:158
@ kELCDIF_PixelFormatXRGB8888
Definition: fsl_elcdif.h:160
@ kELCDIF_PixelFormatRGB888
Definition: fsl_elcdif.h:161
@ kELCDIF_PixelFormatRAW8
Definition: fsl_elcdif.h:156
@ kELCDIF_PixelFormatRGB565
Definition: fsl_elcdif.h:157
@ kELCDIF_AlphaOverride
Definition: fsl_elcdif.h:237
@ kELCDIF_AlphaRop
Definition: fsl_elcdif.h:242
@ kELCDIF_AlphaEmbedded
Definition: fsl_elcdif.h:236
@ kELCDIF_AlphaMultiply
Definition: fsl_elcdif.h:238
@ kELCDIF_DataBus16Bit
Definition: fsl_elcdif.h:168
@ kELCDIF_DataBus18Bit
Definition: fsl_elcdif.h:169
@ kELCDIF_DataBus24Bit
Definition: fsl_elcdif.h:170
@ kELCDIF_DataBus8Bit
Definition: fsl_elcdif.h:167
@ kELCDIF_VsyncActiveHigh
Definition: fsl_elcdif.h:88
@ kELCDIF_HsyncActiveLow
Definition: fsl_elcdif.h:83
@ kELCDIF_DriveDataOnRisingClkEdge
Definition: fsl_elcdif.h:91
@ kELCDIF_DataEnableActiveHigh
Definition: fsl_elcdif.h:90
@ kELCDIF_HsyncActiveHigh
Definition: fsl_elcdif.h:89
@ kELCDIF_DriveDataOnFallingClkEdge
Definition: fsl_elcdif.h:85
@ kELCDIF_VsyncActiveLow
Definition: fsl_elcdif.h:82
@ kELCDIF_DataEnableActiveLow
Definition: fsl_elcdif.h:84
@ kELCDIF_RopMergeAs
Definition: fsl_elcdif.h:259
@ kELCDIF_RopMergeNotAs
Definition: fsl_elcdif.h:260
@ kELCDIF_RopNotMaskAs
Definition: fsl_elcdif.h:264
@ kELCDIF_RopNotCopyAs
Definition: fsl_elcdif.h:262
@ kELCDIF_RopMaskAs
Definition: fsl_elcdif.h:256
@ kELCDIF_RopNotMergeAs
Definition: fsl_elcdif.h:265
@ kELCDIF_RopNot
Definition: fsl_elcdif.h:263
@ kELCDIF_RopXorAs
Definition: fsl_elcdif.h:266
@ kELCDIF_RopNotXorAs
Definition: fsl_elcdif.h:267
@ kELCDIF_RopMaskNotAs
Definition: fsl_elcdif.h:257
@ kELCDIF_RopMaskAsNot
Definition: fsl_elcdif.h:258
@ kELCDIF_RopMergeAsNot
Definition: fsl_elcdif.h:261
@ kELCDIF_TxFifoOverflowInterruptEnable
Definition: fsl_elcdif.h:102
@ kELCDIF_CurFrameDoneInterruptEnable
Definition: fsl_elcdif.h:104
@ kELCDIF_VsyncEdgeInterruptEnable
Definition: fsl_elcdif.h:106
@ kELCDIF_BusMasterErrorInterruptEnable
Definition: fsl_elcdif.h:101
@ kELCDIF_TxFifoUnderflowInterruptEnable
Definition: fsl_elcdif.h:103
@ kELCDIF_VsyncEdge
Definition: fsl_elcdif.h:124
Definition: fsl_elcdif.h:120
Definition: fsl_elcdif.h:119
Definition: fsl_elcdif.h:122
Definition: fsl_elcdif.h:121
@ kELCDIF_Lut1
Definition: fsl_elcdif.h:294
@ kELCDIF_Lut0
Definition: fsl_elcdif.h:293
int32_t status_t
Type used for all status and error return values.
Definition: fsl_common.h:225
Definition: MIMXRT1052.h:27360
Definition: fsl_elcdif.h:274
Definition: fsl_elcdif.h:226
Definition: fsl_elcdif.h:193
Definition: deflate.c:114
