RTEMS 6.1-rc1
flash-headers.h
2
11/*
12 * Copyright (C) 2020 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_IMXRT_FLASH_HEADERS_H
37#define LIBBSP_ARM_IMXRT_FLASH_HEADERS_H
38
39#include <stdint.h>
40#include <fsl_flexspi_nor_config.h>
41#include <fsl_flexspi_nor_boot.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif /* __cplusplus */
46
47__attribute__((section(".boot_hdr.dcd_data")))
48extern const uint8_t imxrt_dcd_data[];
49
50__attribute__((section(".boot_hdr.ivt")))
51extern const ivt imxrt_image_vector_table;
52
53__attribute__((section(".boot_hdr.boot_data")))
54extern const BOOT_DATA_T imxrt_boot_data;
55
56__attribute__((section(".boot_hdr.conf")))
57extern const flexspi_nor_config_t imxrt_flexspi_config;
58
59#ifdef __cplusplus
60}
61#endif /* __cplusplus */
62
63#endif /* LIBBSP_ARM_IMXRT_FLASH_HEADERS_H */
Definition: xnandpsu_onfi.h:181
Definition: fsl_flexspi_nor_boot.h:100
Definition: bootldr.h:60
Serial NOR configuration block.
Definition: fsl_flexspi_nor_config.h:275
Definition: fsl_flexspi_nor_boot.h:29
