RTEMS 6.1-rc1
dpmemdata.h
2
13/* COPYRIGHT (c) 1989-2008.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_RTEMS_DPMEMDATA_H
39#define _RTEMS_RTEMS_DPMEMDATA_H
40
41#include <rtems/rtems/dpmem.h>
43
44#ifdef __cplusplus
45extern "C" {
46#endif
47
59typedef struct {
67 uint32_t length;
69
74
84#define DUAL_PORTED_MEMORY_INFORMATION_DEFINE( max ) \
85 OBJECTS_INFORMATION_DEFINE( \
86 _Dual_ported_memory, \
87 OBJECTS_CLASSIC_API, \
88 OBJECTS_RTEMS_PORTS, \
89 Dual_ported_memory_Control, \
90 max, \
91 OBJECTS_NO_STRING_NAME, \
92 NULL \
93 )
94
97#ifdef __cplusplus
98}
99#endif
100
101#endif
102/* end of include file */
This header file defines the Dual-Ported Memory Manager API.
Objects_Information _Dual_ported_memory_Information
The Classic Dual Ported Memory objects information.
This header file provides data structures used by the implementation and the Application Configuratio...
Definition: dpmemdata.h:59
Objects_Control Object
Definition: dpmemdata.h:61
uint32_t length
Definition: dpmemdata.h:67
void * external_base
Definition: dpmemdata.h:65
void * internal_base
Definition: dpmemdata.h:63
Definition: objectdata.h:61
The information structure used to manage each API class of objects.
Definition: objectdata.h:198
