RTEMS 6.1-rc1
This header file defines the Dual-Ported Memory Manager API. More...
#include <stdint.h>
rtems_status_code rtems_port_create (rtems_name name, void *internal_start, void *external_start, uint32_t length, rtems_id *id)
 Creates a port. More...
rtems_status_code rtems_port_ident (rtems_name name, rtems_id *id)
 Identifies a port by the object name. More...
rtems_status_code rtems_port_delete (rtems_id id)
 Deletes the port. More...
rtems_status_code rtems_port_external_to_internal (rtems_id id, void *external, void **internal)
 Converts the external address to the internal address. More...
rtems_status_code rtems_port_internal_to_external (rtems_id id, void *internal, void **external)
 Converts the internal address to the external address. More...
