RTEMS 6.1-rc1
This header file provides the kernel character input/output support API. More...
void | rtems_putc (char c) |
Outputs the character to the kernel character output device. More... | |
void | rtems_put_char (int c, void *unused) |
Puts the character using rtems_putc() More... | |
int | putk (const char *s) |
Outputs the characters of the string and a newline character to the kernel character output device. More... | |
RTEMS_PRINTFLIKE (1, 2) int printk(const char *fmt | |
Outputs the characters defined by the format string and the arguments to the kernel character output device. More... | |
int | vprintk (const char *fmt, va_list ap) |
Outputs the characters defined by the format string and the variable argument list to the kernel character output device. More... | |
int | rtems_printk_printer (void *unused, const char *fmt, va_list ap) |
int | getchark (void) |
Tries to dequeue a character from the kernel character input device. More... | |
BSP_output_char_function_type | BSP_output_char |
This function pointer references the kernel character output implementation. More... | |
BSP_polling_getchar_function_type | BSP_poll_char |
This function pointer may reference the kernel character input implementation. More... | |
