RTEMS 6.1-rc1
bootcard.h
2
9/*
10 * Copyright (C) 2008, 2014 embedded brains GmbH & Co. KG
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef LIBBSP_SHARED_BOOTCARD_H
35#define LIBBSP_SHARED_BOOTCARD_H
36
37#include <rtems/config.h>
38#include <rtems/bspIo.h>
39#include <rtems/malloc.h>
40#include <rtems/score/memory.h>
41
42#include <bspopts.h>
43
44#ifdef __cplusplus
45extern "C" {
46#endif /* __cplusplus */
47
61extern const char *bsp_boot_cmdline;
62
63void bsp_start(void);
64
65void bsp_reset(void);
66
83RTEMS_NO_RETURN void boot_card(const char *cmdline);
84
85struct Per_CPU_Control;
86
96
99#ifdef __cplusplus
100}
101#endif /* __cplusplus */
102
103#endif /* LIBBSP_SHARED_BOOTCARD_H */
This header file provides the kernel character input/output support API.
This header file provides the interfaces of the Memory Handler.
#define RTEMS_NO_RETURN
Tells the compiler in a function declaration that this function does not return.
Definition: basedefs.h:386
const char * bsp_boot_cmdline
Global pointer to the command line of boot_card().
Definition: bootcard.c:44
void bsp_start_on_secondary_processor(struct Per_CPU_Control *cpu_self)
Standard start routine for secondary processors.
Definition: bspsmp.c:98
Standard system initialization procedure.
Definition: bootcard.c:58
This header file defines interfaces to support and use dynamic memory allocation.
Per CPU Core Structure.
Definition: percpu.h:384
