RTEMS 6.1-rc1
#include <rtems/libio.h>
#include <bsp.h>
#include <rtems/bspIo.h>
#include <rtems/console.h>
#include <bsp/interrupt.h>
#include <libcpu/uart.h>
rtems_device_driver | console_close (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
Console close entry point. More... | |
rtems_device_driver | console_read (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
Console read entry point. More... | |
rtems_device_driver | console_write (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
Console write entry point. More... | |
rtems_device_driver | console_control (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
Console IO control entry point. More... | |
rtems_device_driver | console_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
Console open entry point. More... | |
rtems_device_driver | console_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
Console initialization entry point. More... | |
BSP_output_char_function_type | BSP_output_char = TLL6527_BSP_output_char |
This function pointer references the kernel character output implementation. More... | |
BSP_polling_getchar_function_type | BSP_poll_char = TLL6527_BSP_poll_char |
This function pointer may reference the kernel character input implementation. More... | |
Target: TLL6527v1-0 Compiler:
COPYRIGHT (c) 2010 by ECE Northeastern University.
The license and distribution terms for this file may be found in the file LICENSE in this distribution or at http://www.rtems.org/license
LastChange:
rtems_device_driver console_close | ( | rtems_device_major_number | major, |
rtems_device_minor_number | minor, | ||
void * | arg | ||
This method closes a specific device supported by the console device driver.
[in] | major | is the device driver major number |
[in] | minor | is the device driver minor number |
[in] | arg | is the parameters to this call |
RTEMS_SUCCESSFUL | The device driver is successfully closed. |
rtems_device_driver console_control | ( | rtems_device_major_number | major, |
void * | arg | ||
This method performs an IO Control operation on a specific device supported by the console device driver.
RTEMS_SUCCESSFUL | the device driver IO control operation is successfully performed. |
rtems_device_driver console_initialize | ( | rtems_device_major_number | major, |
void * | arg | ||
This routine initializes the console IO driver.
Parameters
major | major number |
minor | minor number |
Output parameters: NONE
rtems_device_driver console_open | ( | rtems_device_major_number | major, |
void * | arg | ||
This method opens a specific device supported by the console device driver.
RTEMS_SUCCESSFUL | The device driver is successfully opened. |
rtems_device_driver console_read | ( | rtems_device_major_number | major, |
void * | arg | ||
This method reads from a specific device supported by the console device driver.
RTEMS_SUCCESSFUL | The device is successfully read from. |
rtems_device_driver console_write | ( | rtems_device_major_number | major, |
void * | arg | ||
This method writes to a specific device supported by the console device driver.
RTEMS_SUCCESSFUL | The device is successfully written. |
