RTEMS 6.1-rc1
Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
Block Device Buffer Management. More...
#include <rtems/libio.h>
#include <rtems/chain.h>
#include <rtems/blkdev.h>
#include <rtems/diskdevs.h>
struct  rtems_bdbuf_buffer
struct  rtems_bdbuf_buffer::rtems_bdbuf_avl_node
struct  rtems_bdbuf_group
struct  rtems_bdbuf_config
#define RTEMS_BDBUF_MAX_READ_AHEAD_BLOCKS_DEFAULT   0
#define RTEMS_BDBUF_MAX_WRITE_BLOCKS_DEFAULT   16
#define RTEMS_BDBUF_SWAPOUT_TASK_PRIORITY_DEFAULT   15
#define RTEMS_BDBUF_SWAPOUT_TASK_SWAP_PERIOD_DEFAULT   250
#define RTEMS_BDBUF_SWAPOUT_TASK_BLOCK_HOLD_DEFAULT   1000
#define RTEMS_BDBUF_SWAPOUT_WORKER_TASKS_DEFAULT   0
#define RTEMS_BDBUF_SWAPOUT_WORKER_TASK_PRIORITY_DEFAULT    RTEMS_BDBUF_SWAPOUT_TASK_PRIORITY_DEFAULT
#define RTEMS_BDBUF_READ_AHEAD_TASK_PRIORITY_DEFAULT    RTEMS_BDBUF_SWAPOUT_TASK_PRIORITY_DEFAULT
#define RTEMS_BDBUF_TASK_STACK_SIZE_DEFAULT   RTEMS_MINIMUM_STACK_SIZE
#define RTEMS_BDBUF_CACHE_MEMORY_SIZE_DEFAULT   (64 * 512)
#define RTEMS_BDBUF_BUFFER_MIN_SIZE_DEFAULT   (512)
#define RTEMS_BDBUF_BUFFER_MAX_SIZE_DEFAULT   (4096)
typedef struct rtems_bdbuf_group rtems_bdbuf_group
typedef struct rtems_bdbuf_buffer rtems_bdbuf_buffer
typedef struct rtems_bdbuf_config rtems_bdbuf_config
enum  rtems_bdbuf_buf_state {
  RTEMS_BDBUF_STATE_FREE = 0 , RTEMS_BDBUF_STATE_EMPTY , RTEMS_BDBUF_STATE_CACHED , RTEMS_BDBUF_STATE_ACCESS_CACHED ,
  RTEMS_BDBUF_STATE_ACCESS_MODIFIED , RTEMS_BDBUF_STATE_ACCESS_EMPTY , RTEMS_BDBUF_STATE_ACCESS_PURGED , RTEMS_BDBUF_STATE_MODIFIED ,
  RTEMS_BDBUF_STATE_SYNC , RTEMS_BDBUF_STATE_TRANSFER , RTEMS_BDBUF_STATE_TRANSFER_PURGED
 State of a buffer of the cache. More...
rtems_status_code rtems_bdbuf_init (void)
rtems_status_code rtems_bdbuf_get (rtems_disk_device *dd, rtems_blkdev_bnum block, rtems_bdbuf_buffer **bd)
rtems_status_code rtems_bdbuf_read (rtems_disk_device *dd, rtems_blkdev_bnum block, rtems_bdbuf_buffer **bd)
void rtems_bdbuf_peek (rtems_disk_device *dd, rtems_blkdev_bnum block, uint32_t nr_blocks)
 Give a hint which blocks should be cached next. More...
rtems_status_code rtems_bdbuf_release (rtems_bdbuf_buffer *bd)
rtems_status_code rtems_bdbuf_release_modified (rtems_bdbuf_buffer *bd)
rtems_status_code rtems_bdbuf_sync (rtems_bdbuf_buffer *bd)
rtems_status_code rtems_bdbuf_syncdev (rtems_disk_device *dd)
void rtems_bdbuf_purge_dev (rtems_disk_device *dd)
 Purges all buffers corresponding to the disk device dd. More...
rtems_status_code rtems_bdbuf_set_block_size (rtems_disk_device *dd, uint32_t block_size, bool sync)
 Sets the block size of a disk device. More...
void rtems_bdbuf_get_device_stats (const rtems_disk_device *dd, rtems_blkdev_stats *stats)
 Returns the block device statistics.
void rtems_bdbuf_reset_device_stats (rtems_disk_device *dd)
 Resets the block device statistics.
const rtems_bdbuf_config rtems_bdbuf_configuration
