RTEMS 6.1-rc1
ARM co-processor 15 (CP15) API. More...
#define | ARM_CP15_TEXT_SECTION |
#define | ARM_CP15_CACHE_PREPARE_MVA(mva) ((const void *) (((uint32_t) (mva)) & ~0x1fU)) |
#define | ARM_CP15_TLB_PREPARE_MVA(mva) ((const void *) (((uint32_t) (mva)) & ~0x3fU)) |
#define | ARM_CORTEX_A9_ACTL_FW (1U << 0) |
#define | ARM_CORTEX_A9_ACTL_L2_PREFETCH_HINT_ENABLE (1U << 1) |
#define | ARM_CORTEX_A9_ACTL_L1_PREFETCH_ENABLE (1U << 2) |
#define | ARM_CORTEX_A9_ACTL_WRITE_FULL_LINE_OF_ZEROS_MODE (1U << 3) |
#define | ARM_CORTEX_A9_ACTL_SMP (1U << 6) |
#define | ARM_CORTEX_A9_ACTL_EXCL (1U << 7) |
#define | ARM_CORTEX_A9_ACTL_ALLOC_IN_ONE_WAY (1U << 8) |
#define | ARM_CORTEX_A9_ACTL_PARITY_ON (1U << 9) |
#define | ARM_CP15_PMCLRSET_CYCLE_COUNTER 0x80000000 |
#define | ARM_CP15_PMCR_IMP(x) ((x) << 24) |
#define | ARM_CP15_PMCR_IDCODE(x) ((x) << 16) |
#define | ARM_CP15_PMCR_N(x) ((x) << 11) |
#define | ARM_CP15_PMCR_DP (1U << 5) |
#define | ARM_CP15_PMCR_X (1U << 4) |
#define | ARM_CP15_PMCR_D (1U << 3) |
#define | ARM_CP15_PMCR_C (1U << 2) |
#define | ARM_CP15_PMCR_P (1U << 1) |
#define | ARM_CP15_PMCR_E (1U << 0) |
MMU Defines | |
See section B3.8.2, "Short-descriptor format memory region attributes, without TEX remap" in the "ARM Architecture Reference Manual ARMv7-A and ARMv7-R edition". | |
#define | ARM_MMU_SECT_BASE_SHIFT 20 |
#define | ARM_MMU_SECT_BASE_MASK (0xfffU << ARM_MMU_SECT_BASE_SHIFT) |
#define | ARM_MMU_SECT_NS (1U << 19) |
#define | ARM_MMU_SECT_NG (1U << 17) |
#define | ARM_MMU_SECT_S (1U << 16) |
#define | ARM_MMU_SECT_AP_2 (1U << 15) |
#define | ARM_MMU_SECT_TEX_2 (1U << 14) |
#define | ARM_MMU_SECT_TEX_1 (1U << 13) |
#define | ARM_MMU_SECT_TEX_0 (1U << 12) |
#define | ARM_MMU_SECT_TEX_SHIFT 12 |
#define | ARM_MMU_SECT_TEX_MASK (0x3U << ARM_MMU_SECT_TEX_SHIFT) |
#define | ARM_MMU_SECT_AP_1 (1U << 11) |
#define | ARM_MMU_SECT_AP_0 (1U << 10) |
#define | ARM_MMU_SECT_AP_SHIFT 10 |
#define | ARM_MMU_SECT_AP_MASK (0x23U << ARM_MMU_SECT_AP_SHIFT) |
#define | ARM_MMU_SECT_DOMAIN_SHIFT 5 |
#define | ARM_MMU_SECT_DOMAIN_MASK (0xfU << ARM_MMU_SECT_DOMAIN_SHIFT) |
#define | ARM_MMU_SECT_XN (1U << 4) |
#define | ARM_MMU_SECT_C (1U << 3) |
#define | ARM_MMU_SECT_B (1U << 2) |
#define | ARM_MMU_SECT_PXN (1U << 0) |
#define | ARM_MMU_SECT_DEFAULT 0x2U |
#define | ARM_MMU_SECT_GET_INDEX(mva) (((uint32_t) (mva)) >> ARM_MMU_SECT_BASE_SHIFT) |
#define | ARM_MMU_SECT_MVA_ALIGN_UP(mva) |
#define | ARM_MMU_PAGE_TABLE_BASE_SHIFT 10 |
#define | ARM_MMU_PAGE_TABLE_BASE_MASK (0x3fffffU << ARM_MMU_PAGE_TABLE_BASE_SHIFT) |
#define | ARM_MMU_PAGE_TABLE_DOMAIN_SHIFT 5 |
#define | ARM_MMU_PAGE_TABLE_DOMAIN_MASK (0xfU << ARM_MMU_PAGE_TABLE_DOMAIN_SHIFT) |
#define | ARM_MMU_PAGE_TABLE_NS (1U << 3) |
#define | ARM_MMU_PAGE_TABLE_PXN (1U << 2) |
#define | ARM_MMU_PAGE_TABLE_DEFAULT 0x1U |
#define | ARM_MMU_SMALL_PAGE_BASE_SHIFT 12 |
#define | ARM_MMU_SMALL_PAGE_BASE_MASK (0xfffffU << ARM_MMU_SMALL_PAGE_BASE_SHIFT) |
#define | ARM_MMU_SMALL_PAGE_NG (1U << 11) |
#define | ARM_MMU_SMALL_PAGE_S (1U << 10) |
#define | ARM_MMU_SMALL_PAGE_AP_2 (1U << 9) |
#define | ARM_MMU_SMALL_PAGE_TEX_2 (1U << 8) |
#define | ARM_MMU_SMALL_PAGE_TEX_1 (1U << 7) |
#define | ARM_MMU_SMALL_PAGE_TEX_0 (1U << 6) |
#define | ARM_MMU_SMALL_PAGE_TEX_SHIFT 6 |
#define | ARM_MMU_SMALL_PAGE_TEX_MASK (0x3U << ARM_MMU_SMALL_PAGE_TEX_SHIFT) |
#define | ARM_MMU_SMALL_PAGE_AP_1 (1U << 5) |
#define | ARM_MMU_SMALL_PAGE_AP_0 (1U << 4) |
#define | ARM_MMU_SMALL_PAGE_AP_SHIFT 4 |
#define | ARM_MMU_SMALL_PAGE_AP_MASK (0x23U << ARM_MMU_SMALL_PAGE_AP_SHIFT) |
#define | ARM_MMU_SMALL_PAGE_C (1U << 3) |
#define | ARM_MMU_SMALL_PAGE_B (1U << 2) |
#define | ARM_MMU_SMALL_PAGE_XN (1U << 0) |
#define | ARM_MMU_SMALL_PAGE_DEFAULT 0x2U |
#define | ARM_MMU_SMALL_PAGE_GET_INDEX(mva) (((uint32_t) (mva)) >> ARM_MMU_SMALL_PAGE_BASE_SHIFT) |
#define | ARM_MMU_SMALL_PAGE_MVA_ALIGN_UP(mva) |
#define | ARM_MMU_SECT_FLAGS_TO_PAGE_TABLE(flags) |
#define | ARM_MMU_PAGE_TABLE_FLAGS_TO_SECT(flags) |
#define | ARM_MMU_SECT_FLAGS_TO_SMALL_PAGE(flags) |
#define | ARM_MMU_SMALL_PAGE_FLAGS_TO_SECT(flags) |
#define | ARM_MMU_TRANSLATION_TABLE_ENTRY_SIZE 4U |
#define | ARM_MMU_TRANSLATION_TABLE_ENTRY_COUNT 4096U |
#define | ARM_MMU_SMALL_PAGE_TABLE_ENTRY_SIZE 4U |
#define | ARM_MMU_SMALL_PAGE_TABLE_ENTRY_COUNT 256U |
#define | ARM_MMU_DEFAULT_CLIENT_DOMAIN 15U |
#define | ARMV7_MMU_READ_ONLY |
#define | ARMV7_MMU_READ_ONLY_CACHED (ARMV7_MMU_READ_ONLY | ARM_MMU_SECT_TEX_0 | ARM_MMU_SECT_C | ARM_MMU_SECT_B) |
#define | ARMV7_MMU_READ_WRITE |
#define | ARMV7_MMU_READ_WRITE_CACHED |
#define | ARMV7_MMU_DATA_READ_ONLY (ARMV7_MMU_READ_ONLY | ARM_MMU_SECT_TEX_0) |
#define | ARMV7_MMU_DATA_READ_ONLY_CACHED ARMV7_MMU_READ_ONLY_CACHED |
#define | ARMV7_MMU_DATA_READ_WRITE (ARMV7_MMU_READ_WRITE | ARM_MMU_SECT_TEX_0) |
#define | ARMV7_MMU_DATA_READ_WRITE_CACHED ARMV7_MMU_READ_WRITE_CACHED |
#define | ARMV7_MMU_CODE (ARMV7_MMU_READ_ONLY | ARM_MMU_SECT_TEX_0) |
#define | ARMV7_MMU_CODE_CACHED ARMV7_MMU_READ_ONLY_CACHED |
#define | ARMV7_MMU_DEVICE (ARMV7_MMU_READ_WRITE | ARM_MMU_SECT_B) |
Control Register Defines | |
#define | ARM_CP15_CTRL_TE (1U << 30) |
#define | ARM_CP15_CTRL_AFE (1U << 29) |
#define | ARM_CP15_CTRL_TRE (1U << 28) |
#define | ARM_CP15_CTRL_NMFI (1U << 27) |
#define | ARM_CP15_CTRL_EE (1U << 25) |
#define | ARM_CP15_CTRL_VE (1U << 24) |
#define | ARM_CP15_CTRL_XP (1U << 23) |
#define | ARM_CP15_CTRL_U (1U << 22) |
#define | ARM_CP15_CTRL_FI (1U << 21) |
#define | ARM_CP15_CTRL_UWXN (1U << 20) |
#define | ARM_CP15_CTRL_WXN (1U << 19) |
#define | ARM_CP15_CTRL_HA (1U << 17) |
#define | ARM_CP15_CTRL_L4 (1U << 15) |
#define | ARM_CP15_CTRL_RR (1U << 14) |
#define | ARM_CP15_CTRL_V (1U << 13) |
#define | ARM_CP15_CTRL_I (1U << 12) |
#define | ARM_CP15_CTRL_Z (1U << 11) |
#define | ARM_CP15_CTRL_SW (1U << 10) |
#define | ARM_CP15_CTRL_R (1U << 9) |
#define | ARM_CP15_CTRL_S (1U << 8) |
#define | ARM_CP15_CTRL_B (1U << 7) |
#define | ARM_CP15_CTRL_CP15BEN (1U << 5) |
#define | ARM_CP15_CTRL_C (1U << 2) |
#define | ARM_CP15_CTRL_A (1U << 1) |
#define | ARM_CP15_CTRL_M (1U << 0) |
Domain Access Control Defines | |
#define | ARM_CP15_DAC_NO_ACCESS 0x0U |
#define | ARM_CP15_DAC_CLIENT 0x1U |
#define | ARM_CP15_DAC_MANAGER 0x3U |
#define | ARM_CP15_DAC_DOMAIN(index, val) ((val) << (2 * index)) |
Fault Status Register Defines | |
#define | ARM_CP15_FAULT_STATUS_MASK 0x040F |
#define | ARM_CP15_FSR_ALIGNMENT_FAULT 0x00000001 |
#define | ARM_CP15_FSR_BACKGROUND_FAULT 0x0000 |
#define | ARM_CP15_FSR_ACCESS_PERMISSION_FAULT 0x000D |
#define | ARM_CP15_FSR_PRECISE_EXTERNAL_ABORT_FAULT 0x0008 |
#define | ARM_CP15_FSR_IMPRECISE_EXTERNAL_ABORT_FAULT 0x0406 |
#define | ARM_CP15_FSR_PRECISE_PARITY_ERROR_EXCEPTION 0x0006 |
#define | ARM_CP15_FSR_IMPRECISE_PARITY_ERROR_EXCEPTION 0x0408 |
#define | ARM_CP15_FSR_DEBUG_EVENT 0x0002 |
CTR, Cache Type Register Defines | |
The format can be obtained from CP15 by call arm_cp15_cache_type_get_format(arm_cp15_get_cache_type()); | |
#define | ARM_CP15_CACHE_TYPE_FORMAT_ARMV6 0 |
#define | ARM_CP15_CACHE_TYPE_FORMAT_ARMV7 4 |
CCSIDR, Cache Size ID Register Defines | |
#define | ARM_CP15_CACHE_CSS_ID_DATA 0 |
#define | ARM_CP15_CACHE_CSS_ID_INSTRUCTION 1 |
#define | ARM_CP15_CACHE_CSS_LEVEL(level) ((level) << 1) |
uint32_t | arm_cp15_set_translation_table_entries (const void *begin, const void *end, uint32_t section_flags) |
Sets the section_flags for the address range [begin, end). More... | |
void * | arm_cp15_set_exception_handler (Arm_symbolic_exception_name exception, void(*handler)(void)) |
Sets the exception handler in the vector table. More... | |
MMU Functions | |
Cache Functions |
