RTEMS
6.3
Toggle main menu visibility
bsps
include
dev
spi
xilinx-axi-spi-regs.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* Copyright (C) 2021 Jan Sommer, German Aerospace Center (DLR)
5
6
7
* modification, are permitted provided that the following conditions
8
* are met:
9
* 1. Redistributions of source code must retain the above copyright
10
* notice, this list of conditions and the following disclaimer.
11
* 2. Redistributions in binary form must reproduce the above copyright
12
* notice, this list of conditions and the following disclaimer in the
13
* documentation and/or other materials provided with the distribution.
14
15
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25
* POSSIBILITY OF SUCH DAMAGE.
26
27
28
#ifndef LIBBSP_ARM_XILINX_AXI_SPI_REGS_H
29
#define LIBBSP_ARM_XILINX_AXI_SPI_REGS_H
30
31
bsp/utility.h
32
33
#ifdef __cplusplus
34
extern
"C"
35
#endif
36
37
typedef
struct
38
uint32_t reserved1[7];
39
uint32_t globalirq;
40
#define XILINX_AXI_SPI_GLOBAL_IRQ_ENABLE BSP_BIT32(31)
41
uint32_t irqstatus;
42
uint32_t reserved2;
43
uint32_t irqenable;
44
#define XILINX_AXI_SPI_IRQ_CMD_ERR BSP_BIT32(13)
45
#define XILINX_AXI_SPI_IRQ_LOOP_ERR BSP_BIT32(12)
46
#define XILINX_AXI_SPI_IRQ_MSB_ERR BSP_BIT32(11)
47
#define XILINX_AXI_SPI_IRQ_SLV_ERR BSP_BIT32(10)
48
#define XILINX_AXI_SPI_IRQ_CPOL_CPHA_ERR BSP_BIT32(9)
49
#define XILINX_AXI_SPI_IRQ_RXNEMPTY BSP_BIT32(8)
50
#define XILINX_AXI_SPI_IRQ_CS_MODE BSP_BIT32(7)
51
#define XILINX_AXI_SPI_IRQ_TXHALF BSP_BIT32(6)
52
#define XILINX_AXI_SPI_IRQ_RXOVR BSP_BIT32(5)
53
#define XILINX_AXI_SPI_IRQ_RXFULL BSP_BIT32(4)
54
#define XILINX_AXI_SPI_IRQ_TXUF BSP_BIT32(3)
55
#define XILINX_AXI_SPI_IRQ_TXEMPTY BSP_BIT32(2)
56
#define XILINX_AXI_SPI_IRQ_SLV_MODF BSP_BIT32(1)
57
#define XILINX_AXI_SPI_IRQ_MODF BSP_BIT32(0)
58
uint32_t reserved3[5];
59
uint32_t reset;
60
#define XILINX_AXI_SPI_RESET 0x0000000a
61
uint32_t reserved4[7];
62
uint32_t control;
63
#define XILINX_AXI_SPI_CONTROL_LSBFIRST BSP_BIT32(9)
64
#define XILINX_AXI_SPI_CONTROL_MST_TRANS_INHIBIT BSP_BIT32(8)
65
#define XILINX_AXI_SPI_CONTROL_MANUAL_CS BSP_BIT32(7)
66
#define XILINX_AXI_SPI_CONTROL_RX_FIFO_RESET BSP_BIT32(6)
67
#define XILINX_AXI_SPI_CONTROL_TX_FIFO_RESET BSP_BIT32(5)
68
#define XILINX_AXI_SPI_CONTROL_CPHA BSP_BIT32(4)
69
#define XILINX_AXI_SPI_CONTROL_CPOL BSP_BIT32(3)
70
#define XILINX_AXI_SPI_CONTROL_MSTREN BSP_BIT32(2)
71
#define XILINX_AXI_SPI_CONTROL_SPIEN BSP_BIT32(1)
72
#define XILINX_AXI_SPI_CONTROL_LOOP BSP_BIT32(0)
73
uint32_t status;
74
#define XILINX_AXI_SPI_STATUS_CMD_ERR BSP_BIT32(10)
75
#define XILINX_AXI_SPI_STATUS_LOOP_ERR BSP_BIT32(9)
76
#define XILINX_AXI_SPI_STATUS_MSB_ERR BSP_BIT32(8)
77
#define XILINX_AXI_SPI_STATUS_SLV_ERR BSP_BIT32(7)
78
#define XILINX_AXI_SPI_STATUS_CPOL_CPHA_ERR BSP_BIT32(6)
79
#define XILINX_AXI_SPI_STATUS_SLV_MODE BSP_BIT32(5)
80
#define XILINX_AXI_SPI_STATUS_MODF BSP_BIT32(4)
81
#define XILINX_AXI_SPI_STATUS_TXFULL BSP_BIT32(3)
82
#define XILINX_AXI_SPI_STATUS_TXEMPTY BSP_BIT32(2)
83
#define XILINX_AXI_SPI_STATUS_RXFULL BSP_BIT32(1)
84
#define XILINX_AXI_SPI_STATUS_RXEMPTY BSP_BIT32(0)
85
uint32_t txdata;
86
uint32_t rxdata;
87
uint32_t cs;
88
uint32_t tx_fifo_len;
89
uint32_t rx_fifo_len;
90
xilinx_axi_spi
91
92
#ifdef __cplusplus
93
94
#endif
95
96
#endif
/* LIBBSP_ARM_XILINX_AXI_SPI_REGS_H */
utility.h
This header file provides utility macros for BSPs.
xilinx_axi_spi
Definition
xilinx-axi-spi-regs.h:37
