RTEMS 6.3
struct  BspSparcLeon3ValFatalClockInitialization_Context
 Test context for spec:/bsp/sparc/leon3/val/fatal-clock-initialization test case. More...
 RTEMS_SYSINIT_ITEM (OccupyClockInterrupt, RTEMS_SYSINIT_DEVICE_DRIVERS, RTEMS_SYSINIT_ORDER_FIRST)
void BspSparcLeon3ValFatalClockInitialization_Run (rtems_fatal_source source, rtems_fatal_code code)
 Runs the parameterized test case.
