RTEMS 6.3
Tests a fatal error. More...
Files | |
| file | testsuites/validation/bsps/tr-fatal-sparc-leon3-clock-initialization.c |
| file | testsuites/validation/bsps/tr-fatal-sparc-leon3-clock-initialization.h |
| struct | BspSparcLeon3ValFatalClockInitialization_Context |
| Test context for spec:/bsp/sparc/leon3/val/fatal-clock-initialization test case. More... | |
| RTEMS_SYSINIT_ITEM (OccupyClockInterrupt, RTEMS_SYSINIT_DEVICE_DRIVERS, RTEMS_SYSINIT_ORDER_FIRST) | |
| void | BspSparcLeon3ValFatalClockInitialization_Run (rtems_fatal_source source, rtems_fatal_code code) |
| Runs the parameterized test case. | |
This test case performs the following actions:
| void BspSparcLeon3ValFatalClockInitialization_Run | ( | rtems_fatal_source | source, |
| rtems_fatal_code | code ) |
| source | is fatal source. |
| code | is fatal code. |
