RTEMS 6.3
This header file provides interfaces of the SCI support. More...
| struct | tms570_sci_context |
| void | tms570_sci_initialize (tms570_sci_context *ctx) |
| bool | tms570_sci_set_attributes (rtems_termios_device_context *base, const struct termios *term) |
| Set attributes of the HW peripheral. | |
| const rtems_termios_device_handler | tms570_sci_handler_polled |
| Struct containing definitions of polled driver functions. | |
| const rtems_termios_device_handler | tms570_sci_handler_interrupt |
| Struct containing definitions of interrupt driven driver functions. | |
| tms570_sci_context | driver_context_table [] |
| Table including all serial drivers. | |
| bool tms570_sci_set_attributes | ( | rtems_termios_device_context * | base, |
| const struct termios * | t ) |
Sets attributes of the HW peripheral (parity, baud rate, etc.)
| [in] | base | context of the driver |
| [in] | t | termios driver |
| true | peripheral setting is changed |
extern |
Definitions of all serial drivers
extern |
Encapsulates interrupt driven driver functions. Use of this table is determited by defining TMS570_USE_INTERRUPTS
extern |
Encapsulates polled driver functions. Use of this table is determited by not defining TMS570_USE_INTERRUPTS
