This source file contains the implementation of network interaction functions related to the UDP network fake for tftpfs testing.
More...
void | _Tftp_Add_interaction_socket (int domain, int type, int protocol, int result) |
void | _Tftp_Add_interaction_close (int fd, int result) |
void | _Tftp_Add_interaction_bind (int fd, int family, int result) |
void | _Tftp_Add_interaction_send_rrq (int fd, const char *filename, uint16_t dest_port, const char *dest_addr_str, uint16_t block_size, uint16_t window_size, bool result) |
void | _Tftp_Add_interaction_send_wrq (int fd, const char *filename, uint16_t dest_port, const char *dest_addr_str, uint16_t block_size, uint16_t window_size, bool result) |
void | _Tftp_Add_interaction_send_ack (int fd, uint16_t block_num, uint16_t dest_port, const char *dest_addr_str, bool result) |
void | _Tftp_Add_interaction_send_data (int fd, uint16_t block_num, size_t start, size_t len, uint8_t(*get_data)(size_t pos), uint16_t dest_port, const char *dest_addr_str, bool result) |
void | _Tftp_Add_interaction_send_error (int fd, uint16_t error_code, uint16_t dest_port, const char *dest_addr_str, bool result) |
void | _Tftp_Add_interaction_recv_data (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, uint16_t block_num, size_t start, size_t len, uint8_t(*get_data)(size_t pos), bool result) |
void | _Tftp_Add_interaction_recv_ack (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, uint16_t block_num, bool result) |
void | _Tftp_Add_interaction_recv_oack (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, const char *options, size_t options_size, bool result) |
void | _Tftp_Add_interaction_recv_error (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, uint16_t error_code, const char *err_msg, bool result) |
void | _Tftp_Add_interaction_recv_raw (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, size_t len, const uint8_t *bytes, bool result) |
void | _Tftp_Add_interaction_recv_nothing (int fd, uint32_t timeout_ms) |
The UDP Network Fake requires interactions between TFTP client and test (which emulates a TFTP server). The idea is that each test defines a sequence of interactions. In a successful test run all interactions must be carried out one-by-one till the last interaction is reached.
Interactions appear when the TFTP client calls functions like sendto(), recvfrom(), or socket(). Here functions are defined which
- handle such interactions and
- permit the tests to easily defined the sequence of interactions.
