RTEMS
6.3
Toggle main menu visibility
testsuites
fstests
tftpfs
tftpfs_interactions.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
13
14
15
* Copyright (C) 2022 embedded brains GmbH & Co. KG
16
17
18
* modification, are permitted provided that the following conditions
19
* are met:
20
* 1. Redistributions of source code must retain the above copyright
21
* notice, this list of conditions and the following disclaimer.
22
* 2. Redistributions in binary form must reproduce the above copyright
23
* notice, this list of conditions and the following disclaimer in the
24
* documentation and/or other materials provided with the distribution.
25
26
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36
* POSSIBILITY OF SUCH DAMAGE.
37
38
39
#ifndef _TFTPFS_INTERACTIONS_H
40
#define _TFTPFS_INTERACTIONS_H
41
42
#ifdef __cplusplus
43
extern
"C"
44
#endif
45
46
#define NO_BLOCK_SIZE_OPTION 0
47
#define NO_WINDOW_SIZE_OPTION 0
48
#define DO_NOT_WAIT_FOR_ANY_TIMEOUT UINT32_MAX
49
55
56
57
* These functions append an interaction to the list of expected interactions.
58
* For example, _Tftp_Add_interaction_socket() "means":
59
60
* * As next interaction, expect that the TFTP client calls function
61
* socket().
62
* * Expect (i.e. check) that this socket() call will get parameter values
63
* as provided by its parameters `domain`, `type` and `protocol`.
64
* * This call to socket() shall return value of parameter `result`
65
* to the TFTP client.
66
67
* The interactions with functions sendto() and recvfrom() are a bit more
68
* complicated because specific packets are expected to be received or sent.
69
* For example, _Tftp_Add_interaction_send_rrq() appends an interaction
70
* where the TFTP client is expected to call sendto() with an RRQ (Read
71
* Request) packet. _Tftp_Add_interaction_recv_data() appends an interaction
72
* where the TFTP client is expected to call recvfrom() and as result it
73
* receives a data packet (which the interaction writes into the buffer
74
* which the TFTP client provides as parameter in its the recvfrom() call).
75
76
77
void
78
int
domain,
79
int
type,
80
int
protocol,
81
int
result
82
83
84
void
_Tftp_Add_interaction_close(
int
fd,
int
result );
85
86
void
_Tftp_Add_interaction_bind(
int
fd,
int
family,
int
result );
87
88
void
89
int
fd,
90
const
char
*filename,
91
uint16_t dest_port,
92
const
char
*dest_addr_str,
93
uint16_t block_size,
94
uint16_t window_size,
95
bool
result
96
97
98
void
_Tftp_Add_interaction_send_wrq(
99
int
fd,
100
const
char
*filename,
101
uint16_t dest_port,
102
const
char
*dest_addr_str,
103
104
105
bool
result
106
107
108
void
_Tftp_Add_interaction_send_ack(
109
int
fd,
110
uint16_t block_num,
111
uint16_t dest_port,
112
const
char
*dest_addr_str,
113
bool
result
114
115
116
void
_Tftp_Add_interaction_send_data(
117
int
fd,
118
uint16_t block_num,
119
size_t
start,
120
size_t
len,
121
uint8_t (*get_data)(
size_t
pos ),
122
uint16_t dest_port,
123
const
char
*dest_addr_str,
124
bool
result
125
126
127
void
_Tftp_Add_interaction_send_error(
128
int
fd,
129
uint16_t error_code,
130
uint16_t dest_port,
131
const
char
*dest_addr_str,
132
bool
result
133
134
135
136
* _Tftp_Add_interaction_recv_data() permits only a boolean result.
137
* The TFTP client code does not check `errno` and always behaves as if
138
* a return of -1 indicates a timeout. Hence
139
140
* and no special value to distinct timeouts from other errors.
141
142
void
143
int
fd,
144
uint32_t timeout_ms,
145
uint16_t src_port,
146
const
char
*src_addr_str,
147
uint16_t block_num,
148
size_t
start,
149
size_t
len,
150
size_t
pos ),
151
bool
result
152
153
154
void
_Tftp_Add_interaction_recv_ack(
155
int
fd,
156
157
uint16_t src_port,
158
const
char
*src_addr_str,
159
uint16_t block_num,
160
bool
result
161
162
163
void
_Tftp_Add_interaction_recv_oack(
164
int
fd,
165
166
uint16_t src_port,
167
const
char
*src_addr_str,
168
const
char
*options,
169
size_t
options_size,
170
bool
result
171
172
173
void
_Tftp_Add_interaction_recv_error(
174
int
fd,
175
176
uint16_t src_port,
177
const
char
*src_addr_str,
178
179
const
char
*err_msg,
180
bool
result
181
182
183
184
* The TFTP client receives a "raw" packet.
185
186
* Test tests use this function to trigger packet format errors such as:
187
188
* * Too short packets,
189
* * Strings without 0-byte at their end
190
* * Wrong op-codes
191
192
void
_Tftp_Add_interaction_recv_raw(
193
int
fd,
194
195
uint16_t src_port,
196
const
char
*src_addr_str,
197
size_t
len,
198
const
uint8_t *bytes,
199
bool
result
200
201
202
void
_Tftp_Add_interaction_recv_nothing(
203
int
fd,
204
uint32_t timeout_ms
205
206
208
209
#ifdef __cplusplus
210
211
#endif
212
213
#endif
/* _TFTPFS_INTERACTIONS_H */
