RTEMS
6.3
Toggle main menu visibility
bsps
arm
imxrt
mcux-sdk
devices
MIMXRT1166
system_MIMXRT1166_cm7.h
1
2
3
** Processors: MIMXRT1166CVM5A_cm7
4
** MIMXRT1166DVM6A_cm7
5
** MIMXRT1166XVM5A_cm7
6
7
** Compilers: Freescale C/C++ for Embedded ARM
8
** GNU C Compiler
9
** IAR ANSI C/C++ Compiler for ARM
10
** Keil ARM C/C++ Compiler
11
** MCUXpresso Compiler
12
13
** Reference manual: IMXRT1160RM, Rev 0, 03/2021
14
** Version: rev. 0.1, 2020-12-29
15
** Build: b210615
16
17
** Abstract:
18
** Provides a system configuration function and a global variable that
19
** contains the system frequency. It configures the device and initializes
20
** the oscillator (PLL) that is part of the microcontroller device.
21
22
** Copyright 2016 Freescale Semiconductor, Inc.
23
** Copyright 2016-2021 NXP
24
** All rights reserved.
25
26
** SPDX-License-Identifier: BSD-3-Clause
27
28
** http: www.nxp.com
29
** mail: support@nxp.com
30
31
** Revisions:
32
** - rev. 0.1 (2020-12-29)
33
** Initial version.
34
35
36
37
48
49
#ifndef _SYSTEM_MIMXRT1166_cm7_H_
50
#define _SYSTEM_MIMXRT1166_cm7_H_
51
52
#ifdef __cplusplus
53
extern
"C"
54
#endif
55
56
#include <stdint.h>
57
58
59
#ifndef DISABLE_WDOG
60
#define DISABLE_WDOG 1
61
#endif
62
63
/* Define clock source values */
64
65
#define CPU_XTAL_CLK_HZ 24000000UL
/* Value of the external crystal or oscillator clock frequency in Hz */
66
67
#define CPU_CLK1_HZ 0UL
/* Value of the CLK1 (select the CLK1_N/CLK1_P as source) frequency in Hz */
68
/* If CLOCK1_P,CLOCK1_N is choose as the pll bypass clock source, please implement the CLKPN_FREQ define, otherwise 0 will be returned. */
69
70
#define DEFAULT_SYSTEM_CLOCK 528000000UL
/* Default System clock value */
71
72
82
extern
uint32_t SystemCoreClock;
83
91
void
SystemInit
void
92
100
void
SystemCoreClockUpdate
void
101
112
void
SystemInitHook (
void
113
114
#ifdef __cplusplus
115
116
#endif
117
118
#endif
/* _SYSTEM_MIMXRT1166_cm7_H_ */
SystemInit
void SystemInit(void)
Setup the microcontroller system. Initialize the System and update the SystemFrequency variable.
Definition
system_samv71.c:82
void SystemCoreClockUpdate(void)
Update SystemCoreClock variable according to Clock Register Values. The SystemCoreClock variable cont...
Definition
system_samv71.c:158
