RTEMS 6.3
STM32H7xx_System_Exported_Functions
void SystemInit (void)
 Setup the microcontroller system. Initialize the System and update the SystemFrequency variable.
void SystemCoreClockUpdate (void)
 Update SystemCoreClock variable according to Clock Register Values. The SystemCoreClock variable contains the core clock , it can be used by the user application to setup the SysTick timer or configure other parameters.
◆ SystemCoreClockUpdate()
void SystemCoreClockUpdate ( void )
extern
Updates the SystemCoreClock with current core Clock retrieved from cpu registers.
Note
Each time the core clock changes, this function must be called to update SystemCoreClock variable value. Otherwise, any configuration based on this variable will be incorrect.
- The system frequency computed by this function is not the real frequency in the chip. It is calculated based on the predefined constant and the selected clock source:
(*) CSI_VALUE is a constant defined in stm32h7xx_hal.h file (default value 4 MHz) but the real value may vary depending on the variations in voltage and temperature. (**) HSI_VALUE is a constant defined in stm32h7xx_hal.h file (default value 64 MHz) but the real value may vary depending on the variations in voltage and temperature.
(***)HSE_VALUE is a constant defined in stm32h7xx_hal.h file (default value 25 MHz), user has to ensure that HSE_VALUE is same as the real frequency of the crystal used. Otherwise, this function may have wrong result.
  • The result of this function could be not correct when using fractional value for HSE crystal.
    Parameters
    None
    Return values
    None
    Note
    Parameters
    None
    Return values
    None
◆ SystemInit()
void SystemInit ( void )
extern
Setup the microcontroller system. Initialize the System and update the SystemCoreClock variable.
Setup the microcontroller system Initialize the FPU setting, vector table location and External memory configuration.
Setup the microcontroller system Initialize the FPU setting and vector table location configuration.
Parameters
None
Return values
None
