RTEMS 6.3
Data Fields | |
| unsigned int | nodeaddr |
| unsigned int | destkey |
| unsigned int | clkdiv |
| unsigned int | rxmaxlen |
| unsigned int | timer |
| unsigned int | disconnect |
| unsigned int | promiscuous |
| unsigned int | rmapen |
| unsigned int | rmapbufdis |
| unsigned int | linkdisabled |
| unsigned int | linkstart |
| unsigned int | check_rmap_err |
| unsigned int | rm_prot_id |
| unsigned int | tx_blocking |
| unsigned int | tx_block_on_full |
| unsigned int | rx_blocking |
| unsigned int | disable_err |
| unsigned int | link_err_irq |
| rtems_id | event_id |
| unsigned int | is_rmap |
| unsigned int | is_rxunaligned |
| unsigned int | is_rmapcrc |
| unsigned int | nodemask |
| unsigned int | keep_source |
| unsigned int | rtimeout |
