RTEMS
6.3
Toggle main menu visibility
bsps
include
grlib
grspw.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
7
8
9
* COPYRIGHT (c) 2007.
10
* Cobham Gaisler AB.
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
#ifndef __GRSPW_H__
35
#define __GRSPW_H__
36
46
47
grlib/ambapp.h
48
49
#ifdef __cplusplus
50
extern
"C"
51
#endif
52
53
#define SPW_LINKERR_EVENT RTEMS_EVENT_0
54
55
typedef
struct
56
unsigned
int
rxsize;
57
unsigned
int
txdsize;
58
unsigned
int
txhsize;
59
spw_ioctl_packetsize
60
61
#define GRSPW_PKTSEND_OPTION_HDR_CRC 0x1
62
#define GRSPW_PKTSEND_OPTION_DATA_CRC 0x2
63
#define GRSPW_PKTSEND_OPTION_NOCRCLEN(len) ((len & 0xf) << 8)
64
#define GRSPW_PKTSEND_OPTION_NOCRCLEN_MASK 0xf00
65
66
typedef
struct
67
unsigned
int
hlen;
68
char
*hdr;
69
unsigned
int
dlen;
70
char
*data;
71
unsigned
int
sent;
72
unsigned
int
options;
73
spw_ioctl_pkt_send
74
75
typedef
struct
76
unsigned
int
tx_link_err;
77
unsigned
int
rx_rmap_header_crc_err;
78
unsigned
int
rx_rmap_data_crc_err;
79
unsigned
int
rx_eep_err;
80
unsigned
int
rx_truncated;
81
unsigned
int
parity_err;
82
unsigned
int
escape_err;
83
unsigned
int
credit_err;
84
unsigned
int
write_sync_err;
85
unsigned
int
disconnect_err;
86
unsigned
int
early_ep;
87
unsigned
int
invalid_address;
88
unsigned
int
packets_sent;
89
unsigned
int
packets_received;
90
spw_stats
91
92
typedef
struct
93
unsigned
int
nodeaddr;
94
unsigned
int
destkey;
95
unsigned
int
clkdiv;
/* Note: contain both CLKDIVSTART and CLKDIVRUN, but IOCTL_SET_CLKDIV* commands are split into two */
96
unsigned
int
rxmaxlen;
97
unsigned
int
timer;
98
unsigned
int
disconnect;
99
unsigned
int
promiscuous;
100
unsigned
int
rmapen;
101
unsigned
int
rmapbufdis;
102
unsigned
int
linkdisabled;
103
unsigned
int
linkstart;
104
105
unsigned
int
check_rmap_err;
/* check incoming packets for rmap errors */
106
unsigned
int
rm_prot_id;
/* remove protocol id from incoming packets */
107
unsigned
int
tx_blocking;
/* use blocking tx */
108
unsigned
int
tx_block_on_full;
/* block when all tx_buffers are used */
109
unsigned
int
rx_blocking;
/* block when no data is available */
110
unsigned
int
disable_err;
/* disable link automatically when link error is detected */
111
unsigned
int
link_err_irq;
/* generate an interrupt when link error occurs */
112
rtems_id
event_id;
/* task id that should receive link err irq event */
113
114
unsigned
int
is_rmap;
115
unsigned
int
is_rxunaligned;
116
unsigned
int
is_rmapcrc;
117
118
unsigned
int
nodemask;
119
unsigned
int
keep_source;
/* copy source address to user-buffer in read() operations
120
* Note that rm_prot_id has no effect when keep_source is
121
* set.
122
123
unsigned
int
rtimeout;
/* Read timeout if != 0 */
124
spw_config
125
126
#define SPACEWIRE_IOCTRL_SET_NODEADDR 1
127
#define SPACEWIRE_IOCTRL_SET_RXBLOCK 2
128
#define SPACEWIRE_IOCTRL_SET_DESTKEY 4
129
#define SPACEWIRE_IOCTRL_SET_CLKDIV 5
130
#define SPACEWIRE_IOCTRL_SET_TIMER 6
131
#define SPACEWIRE_IOCTRL_SET_DISCONNECT 7
132
#define SPACEWIRE_IOCTRL_SET_PROMISCUOUS 8
133
#define SPACEWIRE_IOCTRL_SET_RMAPEN 9
134
#define SPACEWIRE_IOCTRL_SET_RMAPBUFDIS 10
135
#define SPACEWIRE_IOCTRL_SET_CHECK_RMAP 11
136
#define SPACEWIRE_IOCTRL_SET_RM_PROT_ID 12
137
#define SPACEWIRE_IOCTRL_SET_TXBLOCK 14
138
#define SPACEWIRE_IOCTRL_SET_DISABLE_ERR 15
139
#define SPACEWIRE_IOCTRL_SET_LINK_ERR_IRQ 16
140
#define SPACEWIRE_IOCTRL_SET_EVENT_ID 17
141
#define SPACEWIRE_IOCTRL_SET_PACKETSIZE 20
142
#define SPACEWIRE_IOCTRL_GET_LINK_STATUS 23
143
#define SPACEWIRE_IOCTRL_GET_CONFIG 25
144
#define SPACEWIRE_IOCTRL_GET_STATISTICS 26
145
#define SPACEWIRE_IOCTRL_CLR_STATISTICS 27
146
#define SPACEWIRE_IOCTRL_SEND 28
147
#define SPACEWIRE_IOCTRL_LINKDISABLE 29
148
#define SPACEWIRE_IOCTRL_LINKSTART 30
149
#define SPACEWIRE_IOCTRL_SET_TXBLOCK_ON_FULL 31
150
#define SPACEWIRE_IOCTRL_SET_COREFREQ 32
151
#define SPACEWIRE_IOCTRL_SET_CLKDIVSTART 33
152
#define SPACEWIRE_IOCTRL_SET_NODEMASK 34
153
#define SPACEWIRE_IOCTRL_SET_KEEP_SOURCE 35
154
#define SPACEWIRE_IOCTRL_SET_TCODE_CTRL 36
155
#define SPACEWIRE_IOCTRL_SET_TCODE 37
156
#define SPACEWIRE_IOCTRL_GET_TCODE 38
157
#define SPACEWIRE_IOCTRL_SET_READ_TIMEOUT 39
158
159
#define SPACEWIRE_IOCTRL_START 64
160
#define SPACEWIRE_IOCTRL_STOP 65
161
162
/* Defines what register bits that will be touched
163
* for SPACEWIRE_IOCTRL_SET_TCODE_CTRL
164
165
#define SPACEWIRE_TCODE_CTRL_IE_MSK 0x001
166
#define SPACEWIRE_TCODE_CTRL_TT_MSK 0x004
167
#define SPACEWIRE_TCODE_CTRL_TR_MSK 0x008
168
169
/* Defines what register bits that should be set
170
171
172
#define SPACEWIRE_TCODE_CTRL_IE 0x100
173
#define SPACEWIRE_TCODE_CTRL_TT 0x400
174
#define SPACEWIRE_TCODE_CTRL_TR 0x800
175
176
/* SPACEWIRE_IOCTRL_SET_TCODE argument mask */
177
#define SPACEWIRE_TCODE_TCODE 0x0ff
178
#define SPACEWIRE_TCODE_SET 0x100
/* Set Timecode register */
179
#define SPACEWIRE_TCODE_TX 0x400
180
181
void
grspw_register_drv (
void
182
183
void
grspw_print(
int
options);
184
185
/* Global GRSPW Function pointer called upon timecode receive interrupt */
186
extern
void (*grspw_timecode_callback)
187
void
*pDev,
void
*regs,
int
minor,
unsigned
int
tc);
188
189
190
#ifdef __cplusplus
191
192
#endif
193
195
196
#endif
/* __GRSPW_H__ */
ambapp.h
rtems_id
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition
types.h:94
spw_config
Definition
grspw.h:92
Definition
grspw.h:55
spw_ioctl_pkt_send
Definition
grspw.h:66
spw_stats
Definition
grspw.h:75
