RTEMS 6.3
sai_edma_handle Struct Reference
SAI DMA transfer handle, users should not touch the content of the handle. More...
#include <fsl_sai_edma.h>
edma_handle_t * dmaHandle
uint8_t nbytes
uint8_t bytesPerFrame
uint8_t channelMask
uint8_t channelNums
uint8_t channel
uint8_t count
uint32_t state
sai_edma_callback_t callback
void * userData
uint8_t tcd [(SAI_XFER_QUEUE_SIZE+1U) *sizeof(edma_tcd_t)]
sai_transfer_t saiQueue [SAI_XFER_QUEUE_SIZE]
size_t transferSize [SAI_XFER_QUEUE_SIZE]
volatile uint8_t queueUser
volatile uint8_t queueDriver
Field Documentation
◆ bytesPerFrame
uint8_t sai_edma_handle::bytesPerFrame
Bytes in a frame
◆ callback
sai_edma_callback_t sai_edma_handle::callback
Callback for users while transfer finish or error occurs
◆ channel
uint8_t sai_edma_handle::channel
Which data channel
◆ channelMask
uint8_t sai_edma_handle::channelMask
Enabled channel mask value, reference _sai_channel_mask
◆ channelNums
uint8_t sai_edma_handle::channelNums
total enabled channel nums
◆ count
uint8_t sai_edma_handle::count
The transfer data count in a DMA request
◆ dmaHandle
edma_handle_t* sai_edma_handle::dmaHandle
DMA handler for SAI send
◆ nbytes
uint8_t sai_edma_handle::nbytes
eDMA minor byte transfer count initially configured.
◆ queueDriver
volatile uint8_t sai_edma_handle::queueDriver
Index for driver to get the transfer data and size
◆ queueUser
volatile uint8_t sai_edma_handle::queueUser
Index for user to queue transfer.
◆ saiQueue
sai_transfer_t sai_edma_handle::saiQueue[SAI_XFER_QUEUE_SIZE]
Transfer queue storing queued transfer.
◆ state
uint32_t sai_edma_handle::state
Internal state for SAI eDMA transfer
◆ tcd
uint8_t sai_edma_handle::tcd[(SAI_XFER_QUEUE_SIZE+1U) *sizeof(edma_tcd_t)]
TCD pool for eDMA transfer.
◆ transferSize
size_t sai_edma_handle::transferSize[SAI_XFER_QUEUE_SIZE]
Data bytes need to transfer
◆ userData
void* sai_edma_handle::userData
User callback parameter
