RTEMS 6.3
fsl_sai_edma.h
1/*
2 * Copyright (c) 2015, Freescale Semiconductor, Inc.
3 * Copyright 2016-2021 NXP
4 * All rights reserved.
5 *
6 * SPDX-License-Identifier: BSD-3-Clause
7 */
8#ifndef _FSL_SAI_EDMA_H_
9#define _FSL_SAI_EDMA_H_
10
11#include "fsl_edma.h"
12#include "fsl_sai.h"
13
19
20/*******************************************************************************
21 * Definitions
22 ******************************************************************************/
23
26#define FSL_SAI_EDMA_DRIVER_VERSION (MAKE_VERSION(2, 5, 0))
28
29typedef struct sai_edma_handle sai_edma_handle_t;
30
32typedef void (*sai_edma_callback_t)(I2S_Type *base, sai_edma_handle_t *handle, status_t status, void *userData);
33
53
54/*******************************************************************************
55 * APIs
56 ******************************************************************************/
57#if defined(__cplusplus)
58extern "C" {
59#endif
60
65
80 sai_edma_handle_t *handle,
81 sai_edma_callback_t callback,
82 void *userData,
83 edma_handle_t *txDmaHandle);
84
99 sai_edma_handle_t *handle,
100 sai_edma_callback_t callback,
101 void *userData,
102 edma_handle_t *rxDmaHandle);
103
122 sai_edma_handle_t *handle,
124 uint32_t mclkSourceClockHz,
125 uint32_t bclkSourceClockHz);
126
145 sai_edma_handle_t *handle,
147 uint32_t mclkSourceClockHz,
148 uint32_t bclkSourceClockHz);
149
170void SAI_TransferTxSetConfigEDMA(I2S_Type *base, sai_edma_handle_t *handle, sai_transceiver_t *saiConfig);
171
191void SAI_TransferRxSetConfigEDMA(I2S_Type *base, sai_edma_handle_t *handle, sai_transceiver_t *saiConfig);
192
212status_t SAI_TransferSendEDMA(I2S_Type *base, sai_edma_handle_t *handle, sai_transfer_t *xfer);
213
233status_t SAI_TransferReceiveEDMA(I2S_Type *base, sai_edma_handle_t *handle, sai_transfer_t *xfer);
234
253 sai_edma_handle_t *handle,
254 sai_transfer_t *xfer,
255 uint32_t loopTransferCount);
256
275 sai_edma_handle_t *handle,
276 sai_transfer_t *xfer,
277 uint32_t loopTransferCount);
278
288void SAI_TransferTerminateSendEDMA(I2S_Type *base, sai_edma_handle_t *handle);
289
299void SAI_TransferTerminateReceiveEDMA(I2S_Type *base, sai_edma_handle_t *handle);
300
310void SAI_TransferAbortSendEDMA(I2S_Type *base, sai_edma_handle_t *handle);
311
321void SAI_TransferAbortReceiveEDMA(I2S_Type *base, sai_edma_handle_t *handle);
322
332status_t SAI_TransferGetSendCountEDMA(I2S_Type *base, sai_edma_handle_t *handle, size_t *count);
333
343status_t SAI_TransferGetReceiveCountEDMA(I2S_Type *base, sai_edma_handle_t *handle, size_t *count);
344
356uint32_t SAI_TransferGetValidTransferSlotsEDMA(I2S_Type *base, sai_edma_handle_t *handle);
357
359
360#if defined(__cplusplus)
361}
362#endif
363
367#endif
struct _edma_tcd edma_tcd_t
eDMA TCD.
struct _edma_handle edma_handle_t
eDMA transfer handle structure
int32_t status_t
Type used for all status and error return values.
Definition fsl_common.h:225
struct _sai_transfer_format sai_transfer_format_t
sai transfer format
#define SAI_XFER_QUEUE_SIZE
SAI transfer queue size, user can refine it according to use case.
Definition fsl_sai.h:204
struct _sai_transfer sai_transfer_t
SAI transfer structure.
struct _sai_transceiver sai_transceiver_t
sai transceiver configurations
Gets byte count sent by SAI.
Definition fsl_sai_edma.c:960
Aborts a SAI transfer using eDMA.
Definition fsl_sai_edma.c:830
status_t SAI_TransferSendLoopEDMA(I2S_Type *base, sai_edma_handle_t *handle, sai_transfer_t *xfer, uint32_t loopTransferCount)
Performs a non-blocking SAI loop transfer using eDMA.
Definition fsl_sai_edma.c:671
Gets valid transfer slot.
Definition fsl_sai_edma.c:1020
void(*) sai_edma_callback_t(I2S_Type *base, sai_edma_handle_t *handle, status_t status, void *userData)
SAI eDMA transfer callback function for finish and error.
Definition fsl_sai_edma.h:32
Aborts a SAI receive using eDMA.
Definition fsl_sai_edma.c:870
void SAI_TransferRxCreateHandleEDMA(I2S_Type *base, sai_edma_handle_t *handle, sai_edma_callback_t callback, void *userData, edma_handle_t *rxDmaHandle)
Initializes the SAI Rx eDMA handle.
Definition fsl_sai_edma.c:225
Configures the SAI Tx.
Definition fsl_sai_edma.c:322
void SAI_TransferRxSetFormatEDMA(I2S_Type *base, sai_edma_handle_t *handle, sai_transfer_format_t *format, uint32_t mclkSourceClockHz, uint32_t bclkSourceClockHz)
Configures the SAI Rx audio format.
Definition fsl_sai_edma.c:377
Terminate all SAI send.
Definition fsl_sai_edma.c:910
void SAI_TransferTxSetFormatEDMA(I2S_Type *base, sai_edma_handle_t *handle, sai_transfer_format_t *format, uint32_t mclkSourceClockHz, uint32_t bclkSourceClockHz)
Configures the SAI Tx audio format.
Definition fsl_sai_edma.c:270
Performs a non-blocking SAI transfer using DMA.
Definition fsl_sai_edma.c:486
Terminate all SAI receive.
Definition fsl_sai_edma.c:935
void SAI_TransferTxCreateHandleEDMA(I2S_Type *base, sai_edma_handle_t *handle, sai_edma_callback_t callback, void *userData, edma_handle_t *txDmaHandle)
Initializes the SAI eDMA handle.
Definition fsl_sai_edma.c:184
Performs a non-blocking SAI receive using eDMA.
Definition fsl_sai_edma.c:580
status_t SAI_TransferReceiveLoopEDMA(I2S_Type *base, sai_edma_handle_t *handle, sai_transfer_t *xfer, uint32_t loopTransferCount)
Definition fsl_sai_edma.c:755
Gets byte count received by SAI.
Definition fsl_sai_edma.c:989
Configures the SAI Rx.
Definition fsl_sai_edma.c:429
Definition MIMXRT1052.h:23296
Definition mknod-pack_dev.c:254
SAI DMA transfer handle, users should not touch the content of the handle.
Definition fsl_sai_edma.h:36
edma_handle_t * dmaHandle
Definition fsl_sai_edma.h:37
uint8_t nbytes
Definition fsl_sai_edma.h:38
uint8_t channelNums
Definition fsl_sai_edma.h:41
uint8_t tcd[(SAI_XFER_QUEUE_SIZE+1U) *sizeof(edma_tcd_t)]
Definition fsl_sai_edma.h:47
uint32_t state
Definition fsl_sai_edma.h:44
uint8_t channel
Definition fsl_sai_edma.h:42
uint8_t count
Definition fsl_sai_edma.h:43
uint8_t bytesPerFrame
Definition fsl_sai_edma.h:39
size_t transferSize[SAI_XFER_QUEUE_SIZE]
Definition fsl_sai_edma.h:49
uint8_t channelMask
Definition fsl_sai_edma.h:40
volatile uint8_t queueDriver
Definition fsl_sai_edma.h:51
void * userData
Definition fsl_sai_edma.h:46
sai_transfer_t saiQueue[SAI_XFER_QUEUE_SIZE]
Definition fsl_sai_edma.h:48
volatile uint8_t queueUser
Definition fsl_sai_edma.h:50
Definition fsl_sai_edma.h:45
