RTEMS 6.3
rtems_libi2c_bus_ops_ Struct Reference
rtems_status_code(*) init (rtems_libi2c_bus_t *bushdl)
rtems_status_code(*) send_start (rtems_libi2c_bus_t *bushdl)
rtems_status_code(*) send_stop (rtems_libi2c_bus_t *bushdl)
rtems_status_code(*) send_addr (rtems_libi2c_bus_t *bushdl, uint32_t addr, int rw)
int(*) read_bytes (rtems_libi2c_bus_t *bushdl, unsigned char *bytes, int nbytes)
int(*) write_bytes (rtems_libi2c_bus_t *bushdl, unsigned char *bytes, int nbytes)
int(*) ioctl (rtems_libi2c_bus_t *bushdl, int cmd, void *buffer)
