RTEMS 6.3
Data Fields | |
| bool(*) | ctrl_probe (int minor) |
| void(*) | ctrl_initialize (int minor) |
| int(*) | ctrl_control (int minor, uint32_t command, void *arg) |
| void(*) | ctrl_reg_read (int minor, int regist, uint16_t *value) |
| void(*) | ctrl_reg_write (int minor, int regist, uint16_t value) |
| void(*) | ctrl_read_block (int minor, uint32_t block_size, rtems_blkdev_sg_buffer *bufs, uint32_t *cbuf, uint32_t *pos) |
| void(*) | ctrl_write_block (int minor, uint32_t block_size, rtems_blkdev_sg_buffer *bufs, uint32_t *cbuf, uint32_t *pos) |
| rtems_status_code(*) | ctrl_config_io_speed (int minor, uint16_t modes_available) |
