RTEMS 6.3
_pmu_snvs_dig_config Struct Reference
SNVS DIG LDO config. More...
#include <fsl_pmu.h>
pmu_ldo_operate_mode_t mode
pmu_snvs_dig_charge_pump_current_t chargePumpCurrent
pmu_snvs_dig_discharge_resistor_value_t dischargeResistorValue
uint8_t trimValue
bool enablePullDown
bool enableLdoStable
Field Documentation
◆ chargePumpCurrent
pmu_snvs_dig_charge_pump_current_t _pmu_snvs_dig_config::chargePumpCurrent
The current of SNVS DIG LDO's charge pump current.
◆ dischargeResistorValue
pmu_snvs_dig_discharge_resistor_value_t _pmu_snvs_dig_config::dischargeResistorValue
The value of SNVS DIG LDO's Discharge Resistor.
◆ enableLdoStable
bool _pmu_snvs_dig_config::enableLdoStable
Enable/Disable SNVS DIG LDO Stable.
◆ enablePullDown
bool _pmu_snvs_dig_config::enablePullDown
Enable/Disable Pull down.
  • true Enables the feature of using 1M ohm resistor to discharge the LDO output.
  • false Disables the feature of using 1M ohm resistor to discharge the LDO output.
◆ mode
pmu_ldo_operate_mode_t _pmu_snvs_dig_config::mode
The operate mode the SNVS DIG LDO.
◆ trimValue
uint8_t _pmu_snvs_dig_config::trimValue
The trim value.
