RTEMS 6.3
Pmu
struct  _pmu_static_lpsr_ana_ldo_config
 LPSR ANA LDO config. More...
struct  _pmu_static_lpsr_dig_config
 LPSR DIG LDO Config in Static/Software Mode. More...
struct  _pmu_snvs_dig_config
 SNVS DIG LDO config. More...
struct  _pmu_static_bandgap_config
 Bandgap config in static mode. More...
union  _pmu_well_bias_option
 The union of well bias basic options, such as clock source, power source and so on. More...
struct  _pmu_well_bias_option::[struct].wellBiasStruct
struct  _pmu_gpc_body_bias_config
 The stucture of body bias config in GPC mode. More...
struct  _pmu_well_bias_config
 The structure of well bias configuration. More...
#define PMU_HAS_FBB   (0U)
typedef enum _pmu_ldo_name pmu_ldo_name_t
 The name of LDOs.
typedef enum _pmu_body_bias_name pmu_body_bias_name_t
 The name of body bias.
typedef enum _pmu_control_mode pmu_control_mode_t
 The control mode of LDOs/Bandgaps/Body Bias.
typedef enum _pmu_ldo_operate_mode pmu_ldo_operate_mode_t
 The operation mode for the LDOs.
typedef enum _pmu_lpsr_ana_ldo_charge_pump_current pmu_lpsr_ana_ldo_charge_pump_current_t
 The enumeration of LPSR ANA LDO's charge pump current.
typedef enum _pmu_lpsr_ana_ldo_output_range pmu_lpsr_ana_ldo_output_range_t
 The enumeration of LPSR ANA LDO's output range.
typedef enum _pmu_lpsr_dig_voltage_step_time pmu_lpsr_dig_voltage_step_time_t
 The enumeration of voltage step time for LPSR DIG LDO.
typedef enum _pmu_lpsr_dig_target_output_voltage pmu_lpsr_dig_target_output_voltage_t
 The target output voltage of LPSR DIG LDO.
typedef enum _pmu_snvs_dig_charge_pump_current pmu_snvs_dig_charge_pump_current_t
 The enumeration of the SNVS DIG LDO's charge pump current.
typedef enum _pmu_snvs_dig_discharge_resistor_value pmu_snvs_dig_discharge_resistor_value_t
 The enumeration of the SNVS DIG LDO's discharge resistor.
typedef enum _pmu_bandgap_output_VBG_voltage_value pmu_bandgap_output_VBG_voltage_value_t
 The enumeration of output VBG voltage.
typedef enum _pmu_bandgap_output_current_value pmu_bandgap_output_current_value_t
 The enumeration of output current.
typedef enum _pmu_well_bias_power_source pmu_well_bias_power_source_t
 The enumerator of well bias power source.
typedef enum _pmu_bias_area_size pmu_bias_area_size_t
 The enumerator of bias area size.
typedef enum _pmu_well_bias_typical_freq pmu_well_bias_typical_freq_t
 The enumerator of well bias typical frequency.
typedef enum _pmu_adaptive_clock_source pmu_adaptive_clock_source_t
 The enumerator of well bias adaptive clock source.
typedef enum _pmu_freq_reduction pmu_freq_reduction_t
 The enumerator of frequency reduction due to cap increment.
typedef enum _pmu_well_bias_1P8_adjustment pmu_well_bias_1P8_adjustment_t
 The enumerator of well bias 1P8 adjustment.
typedef struct _pmu_static_lpsr_ana_ldo_config pmu_static_lpsr_ana_ldo_config_t
typedef struct _pmu_static_lpsr_dig_config pmu_static_lpsr_dig_config_t
typedef struct _pmu_snvs_dig_config pmu_snvs_dig_config_t
typedef struct _pmu_static_bandgap_config pmu_static_bandgap_config_t
typedef union _pmu_well_bias_option pmu_well_bias_option_t
typedef struct _pmu_well_bias_config pmu_well_bias_config_t
typedef struct _pmu_gpc_body_bias_config pmu_gpc_body_bias_config_t
enum  _pmu_setpoint_map {
  kPMU_SetPoint0 = 1UL << 0UL , kPMU_SetPoint1 = 1UL << 1UL , kPMU_SetPoint2 = 1UL << 2UL , kPMU_SetPoint3 = 1UL << 3UL ,
  kPMU_SetPoint4 = 1UL << 4UL , kPMU_SetPoint5 = 1UL << 5UL , kPMU_SetPoint6 = 1UL << 6UL , kPMU_SetPoint7 = 1UL << 7UL ,
  kPMU_SetPoint8 = 1UL << 8UL , kPMU_SetPoint9 = 1UL << 9UL , kPMU_SetPoint10 = 1UL << 10UL , kPMU_SetPoint11 = 1UL << 11UL ,
  kPMU_SetPoint12 = 1UL << 12UL , kPMU_SetPoint13 = 1UL << 13UL , kPMU_SetPoint14 = 1UL << 14UL , kPMU_SetPoint15 = 1UL << 15UL
 System setpoints enumeration. More...
enum  _pmu_ldo_name { kPMU_PllLdo = 0U , kPMU_LpsrAnaLdo = 1U , kPMU_LpsrDigLdo = 2U , kPMU_SnvsDigLdo = 3U }
 The name of LDOs. More...
enum  _pmu_body_bias_name { kPMU_RBB_SOC = 0x0U , kPMU_RBB_LPSR = 0x1U }
 The name of body bias. More...
enum  _pmu_control_mode { kPMU_StaticMode = 0U , kPMU_GPCMode = 1U }
 The control mode of LDOs/Bandgaps/Body Bias. More...
enum  _pmu_ldo_operate_mode { kPMU_LowPowerMode = 0x0U , kPMU_HighPowerMode = 0x1U }
 The operation mode for the LDOs. More...
enum  _pmu_lpsr_ana_ldo_charge_pump_current { kPMU_LpsrAnaChargePump300nA = 0U , kPMU_LpsrAnaChargePump400nA = 1U , kPMU_LpsrAnaChargePump500nA = 2U , kPMU_LpsrAnaChargePump600nA = 3U }
 The enumeration of LPSR ANA LDO's charge pump current. More...
enum  _pmu_lpsr_ana_ldo_output_range { kPMU_LpsrAnaLdoOutputFrom1P77To1P83 = 0U , kPMU_LpsrAnaLdoOutputFrom1P72To1P77 = 1U , kPMU_LpsrAnaLdoOutputFrom1P82To1P88 = 2U }
 The enumeration of LPSR ANA LDO's output range. More...
enum  _pmu_lpsr_dig_voltage_step_time { kPMU_LpsrDigVoltageStepInc15us = 0x0U , kPMU_LpsrDigVoltageStepInc25us = 0x1U , kPMU_LpsrDigVoltageStepInc50us = 0x2U , kPMU_LpsrDigVoltageStepInc100us = 0x3U }
 The enumeration of voltage step time for LPSR DIG LDO. More...
enum  _pmu_lpsr_dig_target_output_voltage {
  kPMU_LpsrDigTargetStableVoltage0P631V = 0x0U , kPMU_LpsrDigTargetStableVoltage0P65V = 0x1U , kPMU_LpsrDigTargetStableVoltage0P67V = 0x2U , kPMU_LpsrDigTargetStableVoltage0P689V = 0x3U ,
  kPMU_LpsrDigTargetStableVoltage0P709V = 0x4U , kPMU_LpsrDigTargetStableVoltage0P728V = 0x5U , kPMU_LpsrDigTargetStableVoltage0P748V = 0x6U , kPMU_LpsrDigTargetStableVoltage0P767V = 0x7U ,
  kPMU_LpsrDigTargetStableVoltage0P786V = 0x8U , kPMU_LpsrDigTargetStableVoltage0P806V = 0x9U , kPMU_LpsrDigTargetStableVoltage0P825V = 0xAU , kPMU_LpsrDigTargetStableVoltage0P845V = 0xBU ,
  kPMU_LpsrDigTargetStableVoltage0P864V = 0xCU , kPMU_LpsrDigTargetStableVoltage0P883V = 0xDU , kPMU_LpsrDigTargetStableVoltage0P903V = 0xEU , kPMU_LpsrDigTargetStableVoltage0P922V = 0xFU ,
  kPMU_LpsrDigTargetStableVoltage0P942V = 0x10U , kPMU_LpsrDigTargetStableVoltage0P961V = 0x11U , kPMU_LpsrDigTargetStableVoltage0P981V = 0x12U , kPMU_LpsrDigTargetStableVoltage1P0V = 0x13U ,
  kPMU_LpsrDigTargetStableVoltage1P019V = 0x14U , kPMU_LpsrDigTargetStableVoltage1P039V = 0x15U , kPMU_LpsrDigTargetStableVoltage1P058V = 0x16U , kPMU_LpsrDigTargetStableVoltage1P078V = 0x17U ,
  kPMU_LpsrDigTargetStableVoltage1P097V = 0x18U , kPMU_LpsrDigTargetStableVoltage1P117V = 0x19U , kPMU_LpsrDigTargetStableVoltage1P136V = 0x1AU , kPMU_LpsrDigTargetStableVoltage1P155V = 0x1BU ,
  kPMU_LpsrDigTargetStableVoltage1P175V = 0x1CU , kPMU_LpsrDigTargetStableVoltage1P194V = 0x1DU , kPMU_LpsrDigTargetStableVoltage1P214V = 0x1EU , kPMU_LpsrDigTargetStableVoltage1P233V = 0x1FU
 The target output voltage of LPSR DIG LDO. More...
enum  _pmu_snvs_dig_charge_pump_current { kPMU_SnvsDigChargePump12P5nA = 0U , kPMU_SnvsDigChargePump6P25nA = 1U , kPMU_SnvsDigChargePump18P75nA = 2U }
 The enumeration of the SNVS DIG LDO's charge pump current. More...
enum  _pmu_snvs_dig_discharge_resistor_value { kPMU_SnvsDigDischargeResistor15K = 0U , kPMU_SnvsDigDischargeResistor30K = 1U , kPMU_SnvsDigDischargeResistor9K = 2U }
 The enumeration of the SNVS DIG LDO's discharge resistor. More...
enum  _pmu_static_bandgap_power_down_option { kPMU_PowerDownBandgapFully = 1U << 0U , kPMU_PowerDownVoltageReferenceOutputOnly = 1U << 1U , kPMU_PowerDownBandgapVBGUPDetector = 1U << 2U }
 The enumeration of bandgap power down option. More...
enum  _pmu_bandgap_output_VBG_voltage_value {
  kPMU_BandgapOutputVBGVoltageNominal = 0x0U , kPMU_BandgapOutputVBGVoltagePlus10mV = 0x1U , kPMU_BandgapOutputVBGVoltagePlus20mV = 0x2U , kPMU_BandgapOutputVBGVoltagePlus30mV = 0x3U ,
  kPMU_BandgapOutputVBGVoltageMinus10mV = 0x4U , kPMU_BandgapOutputVBGVoltageMinus20mV = 0x5U , kPMU_BandgapOutputVBGVoltageMinus30mV = 0x6U , kPMU_BandgapOutputVBGVoltageMinus40mV = 0x7U
 The enumeration of output VBG voltage. More...
enum  _pmu_bandgap_output_current_value {
  kPMU_OutputCurrent11P5uA = 0x0U , kPMU_OutputCurrent11P8uA = 0x1U , kPMU_OutputCurrent12P1uA = 0x2U , kPMU_OutputCurrent12P4uA = 0x4U ,
  kPMU_OutputCurrent12P7uA = 0x5U , kPMU_OutputCurrent13P0uA = 0x6U , kPMU_OutputCurrent13P3uA = 0x7U
 The enumeration of output current. More...
enum  _pmu_well_bias_power_source { kPMU_WellBiasPowerFromLpsrDigLdo = 0U , kPMU_WellBiasPowerFromDCDC }
 The enumerator of well bias power source. More...
enum  _pmu_bias_area_size {
  kPMU_180uA_6mm2At125C = 0U , kPMU_150uA_5mm2At125C , kPMU_120uA_4mm2At125C , kPMU_90uA_3mm2At125C ,
  kPMU_60uA_2mm2At125C , kPMU_45uA_1P5mm2At125C , kPMU_30uA_1mm2At125C , kPMU_15uA_0P5mm2At125C
 The enumerator of bias area size. More...
enum  _pmu_well_bias_typical_freq {
  kPMU_OscFreqDiv128 = 0U , kPMU_OscFreqDiv64 = 1U , kPMU_OscFreqDiv32 = 2U , kPMU_OscFreqDiv16 = 3U ,
  kPMU_OscFreqDiv8 = 4U , kPMU_OscFreqDiv2 = 6U , kPMU_OscFreq = 7U
 The enumerator of well bias typical frequency. More...
enum  _pmu_adaptive_clock_source { kPMU_AdaptiveClkSourceOscClk = 0U , kPMU_AdaptiveClkSourceChargePumpClk }
 The enumerator of well bias adaptive clock source. More...
enum  _pmu_freq_reduction { kPMU_FreqReductionNone = 0U , kPMU_FreqReduction30PCT , kPMU_FreqReduction40PCT , kPMU_FreqReduction50PCT }
 The enumerator of frequency reduction due to cap increment. More...
enum  _pmu_well_bias_1P8_adjustment {
  kPMU_Cref0fFCspl0fFDeltaC0fF = 0U , kPMU_Cref0fFCspl30fFDeltaCN30fF , kPMU_Cref0fFCspl43fFDeltaCN43fF , kPMU_Cref0fFCspl62fFDeltaCN62fF ,
  kPMU_Cref0fFCspl105fFDeltaCN105fF , kPMU_Cref30fFCspl0fFDeltaC30fF , kPMU_Cref30fFCspl43fFDeltaCN12fF , kPMU_Cref30fFCspl105fFDeltaCN75fF ,
  kPMU_Cref43fFCspl0fFDeltaC43fF , kPMU_Cref43fFCspl30fFDeltaC13fF , kPMU_Cref43fFCspl62fFDeltaCN19fF , kPMU_Cref62fFCspl0fFDeltaC62fF ,
  kPMU_Cref62fFCspl43fFDeltaC19fF , kPMU_Cref105fFCspl0fFDeltaC105fF , kPMU_Cref105fFCspl30fFDeltaC75fF
 The enumerator of well bias 1P8 adjustment. More...
LDOs Control APIs
void PMU_SetPllLdoControlMode (ANADIG_PMU_Type *base, pmu_control_mode_t mode)
 Selects the control mode of the PLL LDO.
void PMU_SwitchPllLdoToGPCMode (ANADIG_PMU_Type *base)
 Switches the PLL LDO from Static/Software Mode to GPC/Hardware Mode.
void PMU_StaticEnablePllLdo (ANADIG_PMU_Type *base)
 Enables PLL LDO via AI interface in Static/Software mode.
void PMU_StaticDisablePllLdo (void)
 Disables PLL LDO via AI interface in Static/Software mode.
void PMU_SetLpsrAnaLdoControlMode (ANADIG_LDO_SNVS_Type *base, pmu_control_mode_t mode)
 Selects the control mode of the LPSR ANA LDO.
void PMU_StaticEnableLpsrAnaLdoBypassMode (ANADIG_LDO_SNVS_Type *base, bool enable)
 Sets the Bypass mode of the LPSR ANA LDO.
void PMU_StaticGetLpsrAnaLdoDefaultConfig (pmu_static_lpsr_ana_ldo_config_t *config)
 Fill the LPSR ANA LDO configuration structure with default settings.
void PMU_StaticLpsrAnaLdoInit (ANADIG_LDO_SNVS_Type *base, const pmu_static_lpsr_ana_ldo_config_t *config)
 Initialize the LPSR ANA LDO in Static/Sofware Mode.
void PMU_StaticLpsrAnaLdoDeinit (ANADIG_LDO_SNVS_Type *base)
 Disable the output of LPSR ANA LDO.
void PMU_SetLpsrDigLdoControlMode (ANADIG_LDO_SNVS_Type *base, pmu_control_mode_t mode)
 Selects the control mode of the LPSR DIG LDO.
void PMU_StaticEnableLpsrDigLdoBypassMode (ANADIG_LDO_SNVS_Type *base, bool enable)
 Turn on/off Bypass mode of the LPSR DIG LDO in Static/Software mode.
void PMU_StaticGetLpsrDigLdoDefaultConfig (pmu_static_lpsr_dig_config_t *config)
 Gets the default configuration of LPSR DIG LDO.
void PMU_StaticLpsrDigLdoInit (ANADIG_LDO_SNVS_Type *base, const pmu_static_lpsr_dig_config_t *config)
 Initialize the LPSR DIG LDO in static mode.
void PMU_StaticLpsrDigLdoDeinit (ANADIG_LDO_SNVS_Type *base)
 Disable the LPSR DIG LDO.
void PMU_GPCSetLpsrDigLdoTargetVoltage (uint32_t setpointMap, pmu_lpsr_dig_target_output_voltage_t voltageValue)
 Sets the voltage step of LPSR DIG LDO in certain setpoint during GPC mode.
void PMU_GetSnvsDigLdoDefaultConfig (pmu_snvs_dig_config_t *config)
 Gets the default config of the SNVS DIG LDO.
void PMU_SnvsDigLdoInit (ANADIG_LDO_SNVS_DIG_Type *base, pmu_ldo_operate_mode_t mode)
 Initialize the SNVS DIG LDO.
void PMU_GPCEnableLdo (pmu_ldo_name_t name, uint32_t setpointMap)
 Controls the ON/OFF of the selected LDO in certain setpoints with GPC mode.
void PMU_GPCSetLdoOperateMode (pmu_ldo_name_t name, uint32_t setpointMap, pmu_ldo_operate_mode_t mode)
 Sets the operating mode of the selected LDO in certain setpoints with GPC mode.
void PMU_GPCEnableLdoTrackingMode (pmu_ldo_name_t name, uint32_t setpointMap)
 Controls the ON/OFF of the selected LDOs' Tracking mode in certain setpoints with GPC mode.
void PMU_GPCEnableLdoBypassMode (pmu_ldo_name_t name, uint32_t setpointMap)
 Controls the ON/OFF of the selected LDOs' Bypass mode in certain setpoints with GPC mode.
void PMU_GPCEnableLdoStandbyMode (pmu_ldo_name_t name, uint32_t setpointMap)
 When STBY assert, enable/disable the selected LDO enter it's Low power mode.
Bandgap Control APIs
void PMU_SetBandgapControlMode (ANADIG_PMU_Type *base, pmu_control_mode_t mode)
 Selects the control mode of the Bandgap Reference.
void PMU_SwitchBandgapToGPCMode (ANADIG_PMU_Type *base)
 Switches the Bandgap from Static/Software Mode to GPC/Hardware Mode.
void PMU_DisableBandgapSelfBiasAfterPowerUp (void)
 Disables Bandgap self bias for best noise performance.
void PMU_EnableBandgapSelfBiasBeforePowerDown (void)
 Enables Bandgap self bias before power down.
void PMU_StaticBandgapInit (const pmu_static_bandgap_config_t *config)
 Initialize Bandgap.
Body Bias Control APIs
void PMU_WellBiasInit (ANADIG_PMU_Type *base, const pmu_well_bias_config_t *config)
 Configures Well bias, such as power source, clock source and so on.
void PMU_GetWellBiasDefaultConfig (pmu_well_bias_config_t *config)
 Gets the default configuration of well bias.
void PMU_SetBodyBiasControlMode (ANADIG_PMU_Type *base, pmu_body_bias_name_t name, pmu_control_mode_t mode)
 Selects the control mode of the Body Bias.
void PMU_EnableBodyBias (ANADIG_PMU_Type *base, pmu_body_bias_name_t name, bool enable)
 Enables/disables the selected body bias.
void PMU_GPCEnableBodyBias (pmu_body_bias_name_t name, uint32_t setpointMap)
 Controls the ON/OFF of the selected body bias in certain setpoints with GPC mode.
void PMU_GPCEnableBodyBiasStandbyMode (pmu_body_bias_name_t name, uint32_t setpointMap)
 Controls the ON/OFF of the selected Body Bias' Wbias power switch in certain setpoints with GPC mode.
void PMU_GPCGetBodyBiasDefaultConfig (pmu_gpc_body_bias_config_t *config)
 Gets the default config of body bias in GPC mode.
void PMU_GPCSetBodyBiasConfig (pmu_body_bias_name_t name, const pmu_gpc_body_bias_config_t *config)
 Sets the config of the selected Body Bias in GPC mode.
Driver version
#define FSL_PMU_DRIVER_VERSION   (MAKE_VERSION(2, 1, 0))
 PMU driver version.
◆ FSL_PMU_DRIVER_VERSION
PMU driver version.
Version 2.1.0.
◆ _pmu_adaptive_clock_source
The adaptive clock source is oscillator clock.
The adaptive clock source is charge pump clock.
◆ _pmu_bandgap_output_current_value
Output 11.5uA current from the bandgap.
Output 11.8uA current from the bandgap.
Output 12.1uA current from the bandgap.
Output 12.4uA current from the bandgap.
Output 12.7uA current from the bandgap.
Output 13.0uA current from the bandgap.
Output 13.3uA current from the bandgap.
◆ _pmu_bandgap_output_VBG_voltage_value
Output nominal voltage.
Output VBG voltage Plus 10mV.
Output VBG voltage Plus 20mV.
Output VBG voltage Plus 30mV.
Output VBG voltage Minus 10mV.
Output VBG voltage Minus 20mV.
Output VBG voltage Minus 30mV.
Output VBG voltage Minus 40mV.
◆ _pmu_bias_area_size
Imax = 180uA; Areamax-RVT = 6.00mm2 at 125C
Imax = 150uA; Areamax-RVT = 5.00mm2 at 125C
Imax = 120uA; Areamax-RVT = 4.00mm2 at 125C
Imax = 90uA; Areamax-RVT = 3.00mm2 at 125C
Imax = 60uA; Areamax-RVT = 2.00mm2 at 125C
Imax = 45uA; Areamax-RVT = 1P5mm2 at 125C
Imax = 30uA; Areamax-RVT = 1.00mm2 at 125C
Imax = 15uA; Areamax-RVT = 0.50mm2 at 125C
◆ _pmu_body_bias_name
kPMU_RBB_SOC
The RBB implemented in SOC.
kPMU_RBB_LPSR
The RBB implemented in LPSRMIX.
◆ _pmu_control_mode
kPMU_StaticMode
Static/Software Control mode.
kPMU_GPCMode
GPC/Hardware Control mode.
◆ _pmu_freq_reduction
No frequency reduction.
30% frequency reduction due to cap increment.
40% frequency reduction due to cap increment.
50% frequency reduction due to cap increment.
◆ _pmu_ldo_name
The name of LDOs.
kPMU_PllLdo
The PLL LDO in SOC domain.
kPMU_LpsrAnaLdo
The LPSR ANA LDO in LPSR domain.
kPMU_LpsrDigLdo
The LPSR DIG LDO in LPSR domain.
kPMU_SnvsDigLdo
The SNVS DIG LDO in SNVS domain.
◆ _pmu_ldo_operate_mode
kPMU_LowPowerMode
LDOs operate in Low power mode.
kPMU_HighPowerMode
LDOs operate in High power mode.
◆ _pmu_lpsr_ana_ldo_charge_pump_current
The current of the charge pump is selected as 300nA.
The current of the charge pump is selected as 400nA.
The current of the charge pump is selected as 500nA.
The current of the charge pump is selected as 600nA.
◆ _pmu_lpsr_ana_ldo_output_range
The output voltage varies from 1.77V to 1.83V.
The output voltage varies from 1.72V to 1.77V.
The output voltage varies from 1.82V to 1.88V.
◆ _pmu_lpsr_dig_target_output_voltage
The target voltage selected as 0.631V
The target voltage selected as 0.65V
The target voltage selected as 0.67V
The target voltage selected as 0.689V
The target voltage selected as 0.709V
The target voltage selected as 0.728V
The target voltage selected as 0.748V
The target voltage selected as 0.767V
The target voltage selected as 0.786V
The target voltage selected as 0.806V
The target voltage selected as 0.825V
The target voltage selected as 0.845V
The target voltage selected as 0.864V
The target voltage selected as 0.883V
The target voltage selected as 0.903V
The target voltage selected as 0.922V
The target voltage selected as 0.942V
The target voltage selected as 0.961V
The target voltage selected as 0.981V
The target voltage selected as 1.0V
The target voltage selected as 1.019V
The target voltage selected as 1.039V
The target voltage selected as 1.058V
The target voltage selected as 1.078V
The target voltage selected as 1.097V
The target voltage selected as 1.117V
The target voltage selected as 1.136V
The target voltage selected as 1.155V
The target voltage selected as 1.175V
The target voltage selected as 1.194V
The target voltage selected as 1.214V
The target voltage selected as 1.233V
◆ _pmu_lpsr_dig_voltage_step_time
LPSR DIG LDO voltage step time selected as 15us.
LPSR DIG LDO voltage step time selected as 25us.
LPSR DIG LDO voltage step time selected as 50us.
LPSR DIG LDO voltage step time selected as 100us.
◆ _pmu_setpoint_map
kPMU_SetPoint0
Set point 0.
kPMU_SetPoint1
Set point 1.
kPMU_SetPoint2
Set point 2.
kPMU_SetPoint3
Set point 3.
kPMU_SetPoint4
Set point 4.
kPMU_SetPoint5
Set point 5.
kPMU_SetPoint6
Set point 6.
kPMU_SetPoint7
Set point 7.
kPMU_SetPoint8
Set point 8.
kPMU_SetPoint9
Set point 9.
kPMU_SetPoint10
Set point 10.
kPMU_SetPoint11
Set point 11.
kPMU_SetPoint12
Set point 12.
kPMU_SetPoint13
Set point 13.
kPMU_SetPoint14
Set point 14.
kPMU_SetPoint15
Set point 15.
◆ _pmu_snvs_dig_charge_pump_current
The current of SNVS DIG LDO's charge pump is selected as 12.5nA.
The current of SNVS DIG LDO's charge pump is selected as 6.25nA.
The current of SNVS DIG LDO's charge pump is selected as 18.75nA.
◆ _pmu_snvs_dig_discharge_resistor_value
The Discharge Resistor is selected as 15K ohm
The Discharge Resistor is selected as 30K ohm
The Discharge Resistor is selected as 9K ohm
◆ _pmu_static_bandgap_power_down_option
Fully power down the bandgap module.
Power down only the reference output section of the bandgap
Power down the VBGUP detector of the bandgap without affecting any additional functionality.
◆ _pmu_well_bias_1P8_adjustment
Cref = 0fF, Cspl = 0fF, DeltaC = 0fF.
Cref = 0fF, Cspl = 30fF, DeltaC = -30fF.
Cref = 0fF, Cspl = 43fF, DeltaC = -43fF.
Cref = 0fF, Cspl = 62fF, DeltaC = -62fF.
Cref = 0fF, Cspl = 105fF, DeltaC = -105fF.
Cref = 30fF, Cspl = 0fF, DeltaC = 30fF.
Cref = 30fF, Cspl = 43fF, DeltaC = -12fF.
Cref = 30fF, Cspl = 105fF, DeltaC = -75fF.
Cref = 43fF, Cspl = 0fF, DeltaC = 43fF.
Cref = 43fF, Cspl = 30fF, DeltaC = 13fF.
Cref = 43fF, Cspl = 62fF, DeltaC = -19fF.
Cref = 62fF, Cspl = 0fF, DeltaC = 62fF.
Cref = 62fF, Cspl = 43fF, DeltaC = 19fF.
Cref = 105fF, Cspl = 0fF, DeltaC = 105fF.
Cref = 105fF, Cspl = 30fF, DeltaC = 75fF.
◆ _pmu_well_bias_power_source
LPSR Dig LDO supplies the power stage and NWELL sampler.
DCDC supplies the power stage and NWELL sampler.
◆ _pmu_well_bias_typical_freq
kPMU_OscFreqDiv128
Typical frequency = osc_freq / 128.
kPMU_OscFreqDiv64
Typical frequency = osc_freq / 64.
kPMU_OscFreqDiv32
Typical frequency = osc_freq / 32.
kPMU_OscFreqDiv16
Typical frequency = osc_freq / 16.
kPMU_OscFreqDiv8
Typical frequency = osc_freq / 8.
kPMU_OscFreqDiv2
Typical frequency = osc_freq / 2.
kPMU_OscFreq
Typical frequency = oscillator frequency.
◆ PMU_DisableBandgapSelfBiasAfterPowerUp()
void PMU_DisableBandgapSelfBiasAfterPowerUp ( void )
This function should be invoked after powering up. This function will wait for the bandgap stable and disable the bandgap self bias. After powering up, it need to wait for the bandgap to get stable and then disable Bandgap Self bias for best noise performance.
brief Disables Bandgap self bias for best noise performance.
This function waits for the bandgap to be stable and disables the bandgap self bias. After being powered up, it needs to wait for the bandgap stable to be stable and then disable Bandgap Self bias for best noise performance.
◆ PMU_EnableBandgapSelfBiasBeforePowerDown()
void PMU_EnableBandgapSelfBiasBeforePowerDown ( void )
This function will enable Bandgap self bias feature before powering down or there will be risk of Bandgap not starting properly.
brief Enables Bandgap self bias before power down.
◆ PMU_EnableBodyBias()
void PMU_EnableBodyBias ( ANADIG_PMU_Type * base,
bool enable )
Parameters
basePMU peripheral base address.
nameThe name of the body bias to be turned on/off, please refer to pmu_body_bias_name_t.
enableUsed to turn on/off the specific body bias.
  • true Enable the selected body bias.
  • false Disable the selected body bias.
brief Enables/disables the selected body bias.
param base PMU peripheral base address. param name The name of the body bias to be turned on/off, please refer to pmu_body_bias_name_t. param enable Used to turn on/off the specific body bias.
◆ PMU_GetSnvsDigLdoDefaultConfig()
void PMU_GetSnvsDigLdoDefaultConfig ( pmu_snvs_dig_config_t * config)
The default values are:
config->mode = kPMU_LowPowerMode;
config->chargePumpCurrent = kPMU_SnvsDigChargePump12P5nA;
config->dischargeResistorValue = kPMU_SnvsDigDischargeResistor15K;
config->trimValue = 0U;
config->enablePullDown = true;
config->enableLdoStable = false;
@ kPMU_SnvsDigDischargeResistor15K
Definition fsl_pmu.h:192
@ kPMU_LowPowerMode
Definition fsl_pmu.h:102
@ kPMU_SnvsDigChargePump12P5nA
Definition fsl_pmu.h:182
Parameters
configPointer to pmu_snvs_dig_config_t.
brief Gets the default config of the SNVS DIG LDO.
The default values are: code config->mode = kPMU_LowPowerMode; config->chargePumpCurrent = kPMU_SnvsDigChargePump12P5nA; config->dischargeResistorValue = kPMU_SnvsDigDischargeResistor15K; config->trimValue = 0U; config->enablePullDown = true; config->enableLdoStable = false; endcode
param config Pointer to the structure pmu_snvs_dig_config_t. Please refer to pmu_snvs_dig_config_t.
◆ PMU_GetWellBiasDefaultConfig()
void PMU_GetWellBiasDefaultConfig ( pmu_well_bias_config_t * config)
Parameters
configThe pointer to the pmu_well_bias_config_t structure.
◆ PMU_GPCEnableBodyBias()
void PMU_GPCEnableBodyBias ( pmu_body_bias_name_t name,
uint32_t setpointMap )
Parameters
nameThe name of the selected body bias. Please see enumeration pmu_body_bias_name_t for details.
setpointMapThe map of setpoints that the specific body bias will be enabled in those setpoints, this value should be the OR'ed Value of _pmu_setpoint_map.
brief Controls the ON/OFF of the selected body bias in the certain setpoints with GPC mode.
param name The name of the selected body bias. Please see the enumeration pmu_body_bias_name_t for details. param setpointMap The map of setpoints that the specific body bias will be enabled in those setpoints, this value should be the OR'ed Value of _pmu_setpoint_map.
◆ PMU_GPCEnableBodyBiasStandbyMode()
void PMU_GPCEnableBodyBiasStandbyMode ( pmu_body_bias_name_t name,
Parameters
nameThe name of the selected body bias. Please see the enumeration pmu_body_bias_name_t for details.
setpointMapThe map of setpoints that the specific body bias's wbias power switch will be turn on in those setpoints, this value should be the OR'ed Value of _pmu_setpoint_map.
brief Controls the ON/OFF of the selected Body Bias' Wbias power switch in certain setpoints with GPC mode.
param name The name of the selected body bias. Please see the enumeration pmu_body_bias_name_t for details. param setpointMap The map of setpoints that the specific body bias's wbias power switch will be turn on in those setpoints, this value should be the OR'ed Value of _pmu_setpoint_map.
◆ PMU_GPCEnableLdo()
void PMU_GPCEnableLdo ( pmu_ldo_name_t name,
Parameters
nameThe name of the selected ldo. Please see enumeration pmu_ldo_name_t for details.
setpointMapThe map of setpoints should be the OR'ed Value of _pmu_setpoint_map, 1b'1 means enable specific ldo in that setpoint. For example, the code PMU_GPCEnableLdo(kPMU_PllLdo, 0x1U) means to enable PLL LDO in setpoint 0 and disable PLL LDO in other setpoint.
brief Controls the ON/OFF of the selected LDO in the certain setpoints with GPC mode.
param name The name of the selected ldo. Please see the enumeration pmu_ldo_name_t for details. param setpointMap The map of setpoints should be the OR'ed Value of _pmu_setpoint_map, 1b'1 means enable specific ldo in that setpoint. For example, the code PMU_GPCEnableLdo(kPMU_PllLdo, 0x1U) means enable PLL LDO in setpoint 0, disable PLL LDO in other setpoint.
◆ PMU_GPCEnableLdoBypassMode()
void PMU_GPCEnableLdoBypassMode ( pmu_ldo_name_t name,
Parameters
setpointMapThe map of setpoints that the LDO bypass mode will be enabled in those setpoints, this value should be the OR'ed Value of _pmu_setpoint_map.
brief Controls the ON/OFF of the selected LDOs' Bypass mode in the certain setpoints with GPC mode.
param name The name of the selected ldo. Please see the enumeration pmu_ldo_name_t for details. param setpointMap The map of setpoints that the LDO bypass mode will be enabled in those setpoints, this value should be the OR'ed Value of _pmu_setpoint_map.
◆ PMU_GPCEnableLdoStandbyMode()
void PMU_GPCEnableLdoStandbyMode ( pmu_ldo_name_t name,
Parameters
setpointMapThe map of setpoints that the LDO low power mode will be enabled in those setpoints if STBY assert, this value should be the OR'ed Value of _pmu_setpoint_map.
brief When STBY assert, enable/disable the selected LDO enter it's Low power mode.
param name The name of the selected ldo. Please see the enumeration pmu_ldo_name_t for details. param setpointMap The map of setpoints that the LDO low power mode will be enabled in those setpoints if STBY assert, this value should be the OR'ed Value of _pmu_setpoint_map.
◆ PMU_GPCEnableLdoTrackingMode()
void PMU_GPCEnableLdoTrackingMode ( pmu_ldo_name_t name,
Parameters
setpointMapThe map of setpoints that the LDO tracking mode will be enabled in those setpoints, this value should be the OR'ed Value of _pmu_setpoint_map.
brief Controls the ON/OFF of the selected LDOs' Tracking mode in the certain setpoints with GPC mode.
param name The name of the selected ldo. Please see the enumeration pmu_ldo_name_t for details. param setpointMap The map of setpoints that the LDO tracking mode will be enabled in those setpoints, this value should be the OR'ed Value of _pmu_setpoint_map.
◆ PMU_GPCGetBodyBiasDefaultConfig()
void PMU_GPCGetBodyBiasDefaultConfig ( pmu_gpc_body_bias_config_t * config)
Parameters
configPointer to structure pmu_gpc_body_bias_config_t.
brief Gets the default config of body bias in GPC mode.
param config Pointer to the structure pmu_gpc_body_bias_config_t.
◆ PMU_GPCSetBodyBiasConfig()
void PMU_GPCSetBodyBiasConfig ( pmu_body_bias_name_t name,
const pmu_gpc_body_bias_config_t * config )
Parameters
brief Sets the config of the selected Body Bias in GPC mode.
param name The name of the selected body bias. Please see the enumeration pmu_body_bias_name_t for details. param config Pointer to the structure pmu_gpc_body_bias_config_t.
◆ PMU_GPCSetLdoOperateMode()
void PMU_GPCSetLdoOperateMode ( pmu_ldo_name_t name,
pmu_ldo_operate_mode_t mode )
Parameters
setpointMapThe map of setpoints should be the OR'ed Value of _pmu_setpoint_map.
modeThe operating mode of the selected ldo. Please refer to enumeration pmu_ldo_operate_mode_t for details.
brief Sets the operating mode of the selected LDO in the certain setpoints with GPC mode.
param name The name of the selected ldo. Please see the enumeration pmu_ldo_name_t for details. param setpointMap The map of setpoints should be the OR'ed Value of _pmu_setpoint_map. param mode The operating mode of the selected ldo. Please refer to the enumeration pmu_ldo_operate_mode_t for details.
◆ PMU_GPCSetLpsrDigLdoTargetVoltage()
void PMU_GPCSetLpsrDigLdoTargetVoltage ( uint32_t setpointMap,
pmu_lpsr_dig_target_output_voltage_t voltageValue )
Note
The function provides the feature to set the voltage step to different setpoints.
Parameters
voltageValueThe voltage step to be set. See enumeration pmu_lpsr_dig_target_output_voltage_t.
brief Sets the voltage step of LPSR DIG LDO in the certain setpoint during GPC mode.
note The function provides the feature to set the voltage step to the different setpoints.
param setpointMap The map of setpoints should be the OR'ed Value of _pmu_setpoint_map. param voltageStep The voltage step to be set.
◆ PMU_SetBandgapControlMode()
void PMU_SetBandgapControlMode ( ANADIG_PMU_Type * base,
pmu_control_mode_t mode )
Parameters
modeThe control mode of the Bandgap Reference. Please refer to pmu_control_mode_t.
brief Selects the control mode of the Bandgap Reference.
param base PMU peripheral base address. param mode The control mode of the Bandgap Reference. Please refer to pmu_control_mode_t.
◆ PMU_SetBodyBiasControlMode()
void PMU_SetBodyBiasControlMode ( ANADIG_PMU_Type * base,
Parameters
nameThe name of the body bias. Please refer to pmu_body_bias_name_t.
modeThe control mode of the Body Bias. Please refer to pmu_control_mode_t.
brief Selects the control mode of the Body Bias.
param base PMU peripheral base address. param name The name of the body bias. Please refer to pmu_body_bias_name_t. param mode The control mode of the Body Bias. Please refer to pmu_control_mode_t.
◆ PMU_SetLpsrAnaLdoControlMode()
void PMU_SetLpsrAnaLdoControlMode ( ANADIG_LDO_SNVS_Type * base,
Parameters
modeThe control mode of the LPSR ANA LDO. Please refer to pmu_control_mode_t.
brief Selects the control mode of the LPSR ANA LDO.
param base PMU peripheral base address. param mode The control mode of the LPSR ANA LDO. Please refer to pmu_control_mode_t.
◆ PMU_SetLpsrDigLdoControlMode()
void PMU_SetLpsrDigLdoControlMode ( ANADIG_LDO_SNVS_Type * base,
Parameters
modeThe control mode of the LPSR DIG LDO. Please refer to pmu_control_mode_t.
brief Selects the control mode of the LPSR DIG LDO.
param base ANADIG_LDO_SNVS peripheral base address. param mode The control mode of the LPSR DIG LDO. Please refer to pmu_control_mode_t.
◆ PMU_SetPllLdoControlMode()
void PMU_SetPllLdoControlMode ( ANADIG_PMU_Type * base,
Parameters
modeThe control mode of the PLL LDO. Please refer to pmu_control_mode_t.
brief Selects the control mode of the PLL LDO.
param base PMU peripheral base address. param mode The control mode of the PLL LDO. Please refer to pmu_control_mode_t.
◆ PMU_SnvsDigLdoInit()
void PMU_SnvsDigLdoInit ( ANADIG_LDO_SNVS_DIG_Type * base,
Parameters
baseLDO SNVS DIG peripheral base address.
modeUsed to control LDO power mode, please refer to pmu_ldo_operate_mode_t.
brief Initialize the SNVS DIG LDO.
param base LDO SNVS DIG peripheral base address. param mode Used to control LDO power mode, please refer to pmu_ldo_operate_mode_t.
◆ PMU_StaticBandgapInit()
void PMU_StaticBandgapInit ( const pmu_static_bandgap_config_t * config)
Initialize Bandgap.
Parameters
configPointer to the structure pmu_static_bandgap_config_t.
brief Init Bandgap.
param config. Pointer to the structure pmu_static_bandgap_config_t. Please refer to pmu_static_bandgap_config_t.
◆ PMU_StaticDisablePllLdo()
void PMU_StaticDisablePllLdo ( void )
brief Disables PLL LDO via AI interface in Static/Software mode.
◆ PMU_StaticEnableLpsrAnaLdoBypassMode()
void PMU_StaticEnableLpsrAnaLdoBypassMode ( ANADIG_LDO_SNVS_Type * base,
bool enable )
Parameters
baseANADIG_LDO_SNVS peripheral base address.
enableEnable/Disable bypass mode.
  • true Enable LPSR ANA Bypass mode.
  • false Disable LPSR ANA Bypass mode.
brief Sets the Bypass mode of the LPSR ANA LDO.
param base ANADIG_LDO_SNVS peripheral base address. param enable Enable/Disable bypass mode.
◆ PMU_StaticEnableLpsrDigLdoBypassMode()
void PMU_StaticEnableLpsrDigLdoBypassMode ( ANADIG_LDO_SNVS_Type * base,
bool enable )
Parameters
enable
  • true Turns on Bypass mode of the LPSR DIG LDO.
  • false Turns off Bypass mode of the LPSR DIG LDO.
brief Turn on/off Bypass mode of the LPSR DIG LDO in Static/Software mode.
param base ANADIG_LDO_SNVS peripheral base address. param enable true - Turn on Bypass mode of the LPSR DIG LDO. false - Turn off Bypass mode of the LPSR DIG LDO.
◆ PMU_StaticEnablePllLdo()
void PMU_StaticEnablePllLdo ( ANADIG_PMU_Type * base)
Parameters
brief Enables PLL LDO via AI interface in Static/Software mode.
◆ PMU_StaticGetLpsrAnaLdoDefaultConfig()
void PMU_StaticGetLpsrAnaLdoDefaultConfig ( pmu_static_lpsr_ana_ldo_config_t * config)
config->mode = kPMU_HighPowerMode;
config->enable2mALoad = true;
config->enable20uALoad = false;
config->enable4mALoad = true;
config->enableStandbyMode = false;
config->driverStrength = kPMU_LpsrAnaLdoDriverStrength0;
config->brownOutDetectorConfig = kPMU_LpsrAnaLdoBrownOutDetectorDisable;
config->chargePumpCurrent = kPMU_LpsrAnaChargePump300nA;
@ kPMU_LpsrAnaChargePump300nA
Definition fsl_pmu.h:111
@ kPMU_LpsrAnaLdoOutputFrom1P77To1P83
Definition fsl_pmu.h:122
@ kPMU_HighPowerMode
Definition fsl_pmu.h:103
Parameters
configPointer to the structure pmu_static_lpsr_ana_ldo_config_t.
brief Fill the LPSR ANA LDO configuration structure with default settings.
The default values are: code config->mode = kPMU_HighPowerMode; config->enable2mALoad = true; config->enable20uALoad = false; config->enable4mALoad = true; config->enableStandbyMode = false; config->driverStrength = kPMU_LpsrAnaLdoDriverStrength0; config->brownOutDetectorConfig = kPMU_LpsrAnaLdoBrownOutDetectorDisable; config->chargePumpCurrent = kPMU_LpsrAnaChargePump300nA; config->outputRange = kPMU_LpsrAnaLdoOutputFrom1P77To1P83; endcode
param config Pointer to the structure pmu_static_lpsr_ana_ldo_config_t. Please refer to pmu_static_lpsr_ana_ldo_config_t.
◆ PMU_StaticGetLpsrDigLdoDefaultConfig()
void PMU_StaticGetLpsrDigLdoDefaultConfig ( pmu_static_lpsr_dig_config_t * config)
config->enableStableDetect = false;
config->voltageStepTime = kPMU_LpsrDigVoltageStepInc50us;
config->brownOutConfig = kPMU_LpsrDigBrownOutDisable;
config->targetVoltage = kPMU_LpsrDigTargetStableVoltage1P0V;
@ kPMU_LpsrDigTargetStableVoltage1P0V
Definition fsl_pmu.h:162
@ kPMU_LpsrDigVoltageStepInc50us
Definition fsl_pmu.h:134
Parameters
configPointer to the structure pmu_static_lpsr_dig_config_t.
configPointer to the structure pmu_static_lpsr_dig_config_t. Please refer to pmu_static_lpsr_dig_config_t.
◆ PMU_StaticLpsrAnaLdoDeinit()
void PMU_StaticLpsrAnaLdoDeinit ( ANADIG_LDO_SNVS_Type * base)
Parameters
brief Disable the output of LPSR ANA LDO.
◆ PMU_StaticLpsrAnaLdoInit()
void PMU_StaticLpsrAnaLdoInit ( ANADIG_LDO_SNVS_Type * base,
const pmu_static_lpsr_ana_ldo_config_t * config )
Parameters
brief Initialize the LPSR ANA LDO in Static/Sofware Mode.
param base ANADIG_LDO_SNVS peripheral base address. param config Pointer to the structure pmu_static_lpsr_ana_ldo_config_t. Please refer to pmu_static_lpsr_ana_ldo_config_t.
◆ PMU_StaticLpsrDigLdoDeinit()
void PMU_StaticLpsrDigLdoDeinit ( ANADIG_LDO_SNVS_Type * base)
Parameters
◆ PMU_StaticLpsrDigLdoInit()
void PMU_StaticLpsrDigLdoInit ( ANADIG_LDO_SNVS_Type * base,
const pmu_static_lpsr_dig_config_t * config )
Parameters
◆ PMU_SwitchBandgapToGPCMode()
void PMU_SwitchBandgapToGPCMode ( ANADIG_PMU_Type * base)
Parameters
brief Switches the Bandgap from Static/Software Mode to GPC/Hardware Mode.
◆ PMU_SwitchPllLdoToGPCMode()
void PMU_SwitchPllLdoToGPCMode ( ANADIG_PMU_Type * base)
Parameters
brief Switches the PLL LDO from Static/Software Mode to GPC/Hardware Mode.
◆ PMU_WellBiasInit()
void PMU_WellBiasInit ( ANADIG_PMU_Type * base,
const pmu_well_bias_config_t * config )
Parameters
configPointer to the pmu_well_bias_config_t structure.
brief Configures Well bias, such as power source, clock source and so on.
param base PMU peripheral base address. param config Pointer to the pmu_well_bias_config_t structure.
