RTEMS 6.3
Semaphore_Control Struct Reference
#include <semdata.h>
union  [union].Core_control
Objects_Control Object
 The object management portion of a semaphore instance.
union  Core_control
The following defines the control block used to manage each semaphore.
Field Documentation
◆ Object
Objects_Control Semaphore_Control::Object
A pointer of the node of active semaphores contains the semaphore flags, see _Semaphore_Get_flags(). The rational for this optimization is a reduction of the semaphore control size in general and the ability to allow a configuration dependent size of the semaphore control block, e.g. for the MrsP semaphores.
