RTEMS 6.3
Test context for spec:/rtems/timer/req/create test case. More...
struct  [struct].Map
void * seized_objects
 This member is used by the T_seize_objects() and T_surrender_objects() support functions.
rtems_id id_value
 This member may contain the object identifier returned by rtems_timer_create().
rtems_name name
 This member specifies the name parameter for the action.
rtems_id * id
 This member specifies the id parameter for the action.
rtems_status_code status
 This member contains the return status of the action.
struct  Map
