RTEMS 6.3
Test context for spec:/rtems/task/req/suspend test case. More...
| struct | [struct].Map |
Data Fields | |
| rtems_id | worker_id |
| This member contains the identifier of a task. | |
| bool | suspend |
| If this member is true, then the worker is suspended before the rtems_task_suspend() call. | |
| rtems_status_code | status |
| This member contains the return value of the rtems_task_suspend() call. | |
| rtems_id | id |
| This member specifies if the id parameter value. | |
| struct | Map |
