RTEMS 6.3
Test context for spec:/rtems/task/req/start test case. More...
struct  [struct].Map
T_scheduler_log_2 scheduler_log
 This member provides the scheduler operation records.
rtems_id worker_id
 This member contains the identifier of a task.
rtems_id extension_id
 This member contains the identifier of the test user extensions.
uint32_t start_extension_calls
 This member contains the count of thread start extension calls.
rtems_task_argument actual_argument
 This member contains the actual argument passed to the entry point.
uint32_t counter
 This member contains the entry point counter.
bool start
 If this member is true, then the worker is started before the rtems_task_start() call.
bool suspend
 If this member is true, then the worker is suspended before the rtems_task_start() call.
rtems_status_code status
 This member contains the return value of the rtems_task_start() call.
rtems_id id
 This member specifies if the id parameter value.
rtems_task_entry entry_point
 This member specifies if the entry_point parameter value.
rtems_task_argument argument
 This member specifies if the argument parameter value.
struct  Map
