RTEMS 6.3
Test context for spec:/rtems/task/req/resume test case. More...
struct  [struct].Map
rtems_id worker_id
 This member contains the identifier of a task.
bool suspend
 If this member is true, then the worker is suspended before the rtems_task_resume() call.
rtems_status_code status
 This member contains the return value of the rtems_task_resume() call.
rtems_id id
 This member specifies if the id parameter value.
struct  Map
