RTEMS 6.3
Test context for spec:/rtems/task/req/get-scheduler test case. More...
struct  [struct].Map
rtems_id scheduler_id_obj
 This member provides the object referenced by the scheduler_id parameter.
rtems_status_code status
 This member contains the return value of the rtems_task_get_scheduler() call.
rtems_id id
 This member specifies if the task_id parameter value.
rtems_id * scheduler_id
 This member specifies if the scheduler_id parameter value.
struct  Map
