RTEMS 6.3
Test context for spec:/rtems/task/req/get-priority test case. More...
struct  [struct].Map
rtems_id scheduler_a_id
 This member contains the scheduler A identifier.
rtems_id scheduler_b_id
 This member contains the scheduler B identifier.
rtems_task_priority priority_obj
 This member provides the object referenced by the priority parameter.
rtems_status_code status
 This member contains the return value of the rtems_task_get_priority() call.
rtems_id task_id
 This member specifies if the task_id parameter value.
rtems_id scheduler_id
 This member specifies if the scheduler_id parameter value.
rtems_id * priority
 This member specifies if the priority parameter value.
struct  Map
